    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 07-07-2016, 01:07 PM   #1186
Originally Posted by goehm View Post
Are you guys still helium soaking your closed cell foams? If so how long do you do it for? I was having problems until I realized I needed to turn the Tupperware container upside down, put it over my foams, THEN shoot the helium inside the container. Otherwise if the container is right side up the helium dissipates instantly! That stuff is like magic.
I put my foams in balloons and then fill them with helium. Once the balloon doesn't stay afloat anymore, you know the helium has soaked in and saturated the foam. Fool proof method.
boucher is offline   Reply With Quote
Old 07-07-2016, 01:20 PM   #1187
Johnn27's Avatar
Trader Rating: 69 (100%+)
Default B/o
Originally Posted by BRSracing View Post
April and yes and yes
I back ordered one 4/30 and it's now telling me August lol ! Although I am not a club member
Johnn27 is offline   Reply With Quote
Old 07-07-2016, 01:26 PM   #1188
Which buggy would you get for an outdoor asphalt track with low profile wooden jumps? B6 or B6D? Thanks!!!
Nitrojeff is offline   Reply With Quote
Old 07-07-2016, 01:52 PM   #1189
Trader Rating: 18 (100%+)
B6, sounds like a really high traction type of track where you would run low ride height and stiff suspension w/ gear diff.
AMessy is offline   Reply With Quote
Old 07-07-2016, 02:00 PM   #1190
BRSracing's Avatar
Trader Rating: 53 (100%+)
I ordered april 29
BRSracing is offline   Reply With Quote
Old 07-07-2016, 02:03 PM   #1191
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
The site is jumping all over the place for dates...I wouldn't worry about it right now. I didn't order until mid-may and was told by tower that I should be fine to get a first batch run. Amain told me that they have double the amt of pre-orders coming. They aren't getting them until the 13th though for some reason. Tower looks to already have some.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-07-2016, 02:03 PM   #1192
Perfect thanks!!!
Old 07-07-2016, 02:26 PM   #1193
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
My order is being picked and packed at Tower Hobbies Happy Thursday!!!
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-07-2016, 02:28 PM   #1194
Jmuck69's Avatar
No...They're packing up a box with a card inside that says "you'll have to wait until the 13th like everyone else"
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-07-2016, 02:35 PM   #1195
lol. In either case, I wont be able to run it for a week....UPS does not deliver on saturdays, so I am looking at a monday the 11th arrival. Same day the LHS get it.
Old 07-07-2016, 03:57 PM   #1196
Finally was able to order all the laydown conversion parts from AE. I want to have a built laydown/gear diff/slipper/motor plate/chassis brace assembly ready for the once in a blue moon I run on carpet. I can just bolt it in, change shock springs and have a pretty good setup.
I think the standup will be superior on the clay tracks I normally run so I'm setting up my D that way out of the box.
Old 07-07-2016, 04:17 PM   #1197
Suspended
Trader Rating: 61 (100%+)
https://www.teamassociated.com/parts...on_conversion/
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-07-2016, 04:57 PM   #1198
im new to the hobby and want to get the B6D for my first . In order to get one would I have already had to order it?
michwolv is offline   Reply With Quote
Old 07-07-2016, 05:03 PM   #1199
Suspended
No, make sure your LHS has them on order, drive there and buy it
Old 07-07-2016, 05:15 PM   #1200
This! And if your LHS happens to also have a track mention this is your first kit and maybe they will throw in some free practice sessions or race entries. At the very least you'll get some free advice!
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
