    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree310Likes
Old 07-07-2016, 09:46 AM   #1171
All the lay down parts are in stock on Associated's site, except for the 39T idler
wiringnatzi is offline   Reply With Quote
Old 07-07-2016, 09:50 AM   #1172
suby723's Avatar
Trader Rating: 21 (100%+)
Well I just ordered a bunch of parts for the b6. Now all I need are the chassis weights and front/rear sways and I'll have about everything.
suby723 is offline   Reply With Quote
Old 07-07-2016, 10:01 AM   #1173
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Johnn27 View Post
It looks like the shock tower in Jason's picture is the long rear shock tower to run the B5 longer rear shocks 91666
Nope, stock tower.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-07-2016, 10:07 AM   #1174
BRSracing's Avatar
Trader Rating: 53 (100%+)
My order status for B6d says its in the process at tower, no longer in backorder status.
BRSracing is offline   Reply With Quote
Old 07-07-2016, 10:08 AM   #1175
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Screen shot or it didnt happen, lol
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-07-2016, 10:12 AM   #1176
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You can be banned for posts like that...
Like Wildcat said...pics or it didn't happen
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-07-2016, 10:19 AM   #1177
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Same for Tower.
VA Beach
F18engineguy is offline   Reply With Quote
Old 07-07-2016, 10:23 AM   #1178
BRSracing's Avatar
LOL nobody believed me months ago when i said the B6 was coming
Old 07-07-2016, 10:25 AM   #1179
BRSracing's Avatar
Here it is, upside down sorry.
Old 07-07-2016, 10:29 AM   #1180
Johnn27's Avatar
Trader Rating: 71 (100%+)
Default B/o
When did you back order and are you a club member? Did you use a coupon code?
Johnn27 is offline   Reply With Quote
Old 07-07-2016, 10:32 AM   #1181
BRSracing's Avatar
April and yes and yes
Old 07-07-2016, 12:03 PM   #1182
nice, you should get the ecash as well.....lucky.....
Old 07-07-2016, 12:27 PM   #1183
Back orders get the Ecash ?
weedsnager is offline   Reply With Quote
Old 07-07-2016, 12:29 PM   #1184
if they process in the "window". today is the last day for July.....
http://www.towerhobbies.com/tow_ecash.html
Customer must provide a valid email address in their account. Tower E-Cash Rewards may also be accessed through Your Account.
Eligible customer purchases include sale, regular, and clearance priced merchandise, but exclude the purchase of Gift Cards/Gift Certificates/EGift Certificates and pending Easy Pay payments. You will only earn E-Cash Rewards on monies successfully paid to Tower Hobbies during the qualifying time frame.
Customer will receive a Tower E-Cash Rewards merchandise gift certificate by email on July 14, 2016 for each individual qualifying order placed between 12:01 AM CT July 1, 2016 and Midnight CT July 7, 2016. Tower E-Cash Rewards are transferrable, redemption dates apply.
Tower E-Cash Rewards merchandise gift certificates issued for this promotion will only be valid for redemption from 12:01 AM CT July 14, 2016 through Midnight CT July 20, 2016. Tower Hobbies reserves the right to modify these promotion dates. Must be a Super Saver Club Member on July 14, 2016 to redeem.
Old 07-07-2016, 01:05 PM   #1185
goehm's Avatar
Trader Rating: 44 (100%+)
Originally Posted by tsair View Post
The clears are nice, but they don't hold up to most of the traction compounds, so I don't recommend them unless you like going through a set of wheels faster than your tires.
Make sure you get the PET wheels, they have a number 5 in the recycle symbol on the insides of the wheels. And make sure you recycle them after you're done. Most of the bigger indoor tracks have a bin right next to the Coke machine.
Are you guys still helium soaking your closed cell foams? If so how long do you do it for? I was having problems until I realized I needed to turn the Tupperware container upside down, put it over my foams, THEN shoot the helium inside the container. Otherwise if the container is right side up the helium dissipates instantly! That stuff is like magic.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
05PSD, ICEMAN96, valk
