    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 07-07-2016, 03:07 AM   #1156
Trader Rating: 18 (100%+)
Originally Posted by F18engineguy View Post
Is there a typo in this list? 91709. Is the chassis brace the same as the waterfall brace?
Yes, AE Part #91709 is called "B6 Chassis Braces" and that part number consists of both the waterfall brace for the standup and lay down transmissions.
AMessy is offline   Reply With Quote
Old 07-07-2016, 04:04 AM   #1157
celt's Avatar
Default B6 Side Rails
Are the two slots in the siderails for taping your cell in? I had not seen them before because of the picture angles. I see a lot of guys doing that.
https://www.amainhobbies.com/team-as...c91652/p507399
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is online now   Reply With Quote
Old 07-07-2016, 05:17 AM   #1158
Mason's Avatar
might fit velcro straps..
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 07-07-2016, 07:03 AM   #1159
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Double sided tape instead. Most people won't tape them in like they do in sedan's.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-07-2016, 07:07 AM   #1160
Suspended
Trader Rating: 61 (100%+)
Added flex.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-07-2016, 07:13 AM   #1161
Default B6 on Clay
I got a B6 in Australia
Its a impressive kit, i bucked the trend and went the B6 for Clay
It is so different to the b5m.
Lots of good stuff to report
The front end feels much more tight
The laydown feels so nice going around corners for me
It accelerates very fast.
The bad- The manual is full of mostly small and a couple large errors.
I started marking them down so i can try to help people with them.
I have some video from tonight racing with 2 b6d's + my B6 on indoor clay i will post
Dmitri Tech is offline   Reply With Quote
Old 07-07-2016, 07:22 AM   #1162
Suspended
Wires for days!
Old 07-07-2016, 08:51 AM   #1163
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Jason Snder posted this. Looks like a conversion kit might be coming
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-07-2016, 09:01 AM   #1164
makes it easier!
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 07-07-2016, 09:17 AM   #1165
Johnn27's Avatar
Trader Rating: 69 (100%+)
Default New B6 kits
I saw a pic Kinwald posted last week of his kit on Facebook when he started building and one of the bags had aluminum rear suspension holders, can anyone confirm if this new car includes rear aluminum C/D suspension holders ?
Johnn27 is offline   Reply With Quote
Old 07-07-2016, 09:20 AM   #1166
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Johnn27 View Post
I saw a pic Kinwald posted last week of his kit when he started building and one of the bags had aluminum rear suspension holders, can anyone confirm if this new car includes rear aluminum C/D suspension holders ?
It includes an Aluminum C mount...the D mount (furthest back) is plastic. You may also need a set of inserts (they are the same for C/D mount), not positive though. Better to have and not need than need and not have.
Tower / AE have quite a bit of parts up right now....amain has some.
Aluminum D mount: 91688
Inserts: 92014
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-07-2016, 09:24 AM   #1167
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Is the shock tower required with the conversion kit Jason posted a picture of
VA Beach
F18engineguy is offline   Reply With Quote
Old 07-07-2016, 09:26 AM   #1168
Super Moderator
Same shock tower for the B6/B6D. Not sure why that is pictured.
Old 07-07-2016, 09:30 AM   #1169
yeah, no idea why he posted a picture of the stock tower. Maybe that was in package from AE, and he just posted everything in the package.
Old 07-07-2016, 09:46 AM   #1170
Johnn27's Avatar
It looks like the shock tower in Jason's picture is the long rear shock tower to run the B5 longer rear shocks 91666
Currently Active Users Viewing This Thread: 6 (3 members and 3 guests)
Kelseyrc, Payton 34, Sean Cochran
