    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 07-01-2016, 09:28 AM   #1036
VegasHB's Avatar
Our local track owner got a B6 yesterday. AE did some testing here so they sent him a kit for letting them use the track. Pretty cool.
https://www.facebook.com/702-RC-Raceway-301311043430/
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 07-01-2016, 10:38 AM   #1037
Originally Posted by Johnn27 View Post
Just get the longer rear shock tower and you can run the b5 rear shocks. I believe the part number is listed s couple pages back .
Thanks for trying to help, but I posted that right in the post that you quoted. I'd rather have had the shorter bodies but I can just buy them or the tower. No big deal.
mx836 is offline   Reply With Quote
Old 07-01-2016, 11:57 AM   #1038
The rear shocks being the same as the truck fronts has been talked about since the car was announced, not sure how you missed it. But at least you have an option to still use the longer ones.
boucher is offline   Reply With Quote
Old 07-01-2016, 04:27 PM   #1039
Yeah, after I make another purchase. Like I said, not a big deal, but it wasn't listed in any literature from Associated that I've seen. I don't eat, sleep, and breathe RC so it's possible that I just missed it. Just wanted to give a heads up to those that missed it as well.
Old 07-01-2016, 06:43 PM   #1040
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/07/mip-b65...-bi-metal-kit/
RCBuddha is offline   Reply With Quote
Old 07-01-2016, 06:51 PM   #1041
RCBuddha's Avatar
http://www.redrc.net/2016/07/team-as...ium-screw-kit/
Old 07-01-2016, 08:35 PM   #1042
rvrslt1's Avatar
Trader Rating: 24 (100%+)
So I tried to order a b6d from LA Partshouse today with the 10% off for the 4th and it says sold out. Called and guess they are sold out of what they may get on the 11th so they will not take any more preorders.
That's crap as I was looking forward to my 10% off.
rvrslt1 is offline   Reply With Quote
Old 07-01-2016, 11:47 PM   #1043
hello every one. First post on rc tech and i like what i see here. I race at trcr in tacoma with my b5m light,. t5m, and in a few weeks a b6d. I looked at the b6 and the b6d manual . Both are high quality cars and the build should go well but im sure a few duh questions i will ask. Btw, my last rc racing was back in 1987 so go easy.
hunsaker204 is offline   Reply With Quote
Old 07-02-2016, 02:47 AM   #1044
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Welcome to the forum!
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 07-02-2016, 03:51 AM   #1045
Welcome back into the hobby! If you stick around in here long enough, you'll see a bunch of "duh" questions and might not need to ask them yourself. My advice is to read the thread from the beginning -a little long, but worth it- and you may answer some of your own questions that way. Use the first page and wiki, they have tons of information in them. If your answers aren't found there, or if you're still unsure of something, ask away and most of us will be glad to try and help.
Old 07-02-2016, 06:14 AM   #1046
RCBuddha's Avatar
http://www.redrc.net/2016/07/t-works...rnbuckle-sets/
http://www.redrc.net/2016/07/team-as...-wing-buttons/
Old 07-02-2016, 07:20 AM   #1047
You can get better than that at Tower Hobbies with their coupon codes. You can pre-order all you want and they will have stock for sure for anyone after the pre-order list as they get so many.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 07-02-2016, 08:48 AM   #1048
PolarRoller's Avatar
Thumbs up
Originally Posted by RCBuddha View Post
Dude... If you don't stop posting links to all these aftermarket parts my wife and kid will end up on the streets I'm still over a week away from getting my kit and I already have a wish list a mile long on several different sites. "Sorry Honey, we can go to Disney world some other time, and the boy will do fine in public school.."
PolarRoller is offline   Reply With Quote
Old 07-02-2016, 10:23 AM   #1049
Thanks guys I have a box full of new parts for the new car. Not too much bling but man i cant resist
Old 07-03-2016, 10:47 AM   #1050
suby723's Avatar
Trader Rating: 21 (100%+)
What battery weight is Ryan cav. Using on his b6 eos setup? All I seem to find is the servo and esc weights.
suby723 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
abailey21
