    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 06-30-2016, 05:20 PM   #1021
function>form's Avatar
Trader Rating: 43 (100%+)
For those of you ordering from tower, order status now says early July
Josh Medina
Bumps and Jumps rc
function>form is offline   Reply With Quote
Old 06-30-2016, 05:46 PM   #1022
My definition of early July is tomorrow !!
weedsnager is offline   Reply With Quote
Old 06-30-2016, 05:48 PM   #1023
Silverstonev8's Avatar
Lol!
Silverstonev8 is offline   Reply With Quote
Old 06-30-2016, 06:37 PM   #1024
Cridd's Avatar
Trader Rating: 16 (100%+)
That is funnnnnay.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 06-30-2016, 06:42 PM   #1025
Trader Rating: 18 (100%+)
Lol, the UPS trucks are probably just pulling out now for the midnight deliveries!
AMessy is offline   Reply With Quote
Old 06-30-2016, 07:32 PM   #1026
bilster44's Avatar
I remember getting my 5M pretty early from them
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 06-30-2016, 08:29 PM   #1027
Kegman21's Avatar
Question is will they ship all the parts also. Early July for the kit and when for the parts?
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Old 06-30-2016, 08:54 PM   #1028
I doubt ups is even shipping on the 4th so even if it was very early July our kits would be delayed atleast a day or in my case my Nero won't be here until Tuesday or Wednesday i assume
Slashn77 is offline   Reply With Quote
Old 06-30-2016, 10:01 PM   #1029
3srcracing's Avatar
Trader Rating: 25 (100%+)
Anyone notice when you backorder off Tower it make you pre order two of everything?
A Main Hobbies | Protek R/C | Team Powers R/C | Cheater Racing
3srcracing is offline   Reply With Quote
Old 06-30-2016, 10:16 PM   #1030
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
yeah, that is AE that makes them do that. something about parts under 9.99
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-30-2016, 10:16 PM   #1031
tsair's Avatar
I didn't see this explicitly covered in the wiki -- can you put a B6 gear diff in a B5M?
I ordered the B6, but am going to keep my B5M for my son and will probably throw the gear diff in there if it fits, just for easy of maintenance/durability reasons. I'll definitely be using a ball diff in my B6.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 07-01-2016, 12:52 AM   #1032
i dont think so; according to this post a few pages back:
the b6 gear diff is 2mm wider than the one for the b5. you can shim the b5 gear diff to drop into the b6 but not visa versa
shdwboxn is offline   Reply With Quote
Old 07-01-2016, 03:09 AM   #1033
I should have a B6D next week in Australia, getting a bit worried about part availability.
Amain has nothing listed, LA parts has them listed but no stock of spares.
What are you guys doing for spares?
Dmitri Tech is offline   Reply With Quote
Old 07-01-2016, 05:15 AM   #1034
Parts should be available on or before July 11th. From rc10.com, your LHS, etc.
Mxer210 is offline   Reply With Quote
Old 07-01-2016, 05:22 AM   #1035
Also the car is VERY light! I built it with only a few option parts and only 1 of them being lighter weight which was the Ti Turnbuckles and weighed in at 1498 and that's with 25 grams under the battery, it is the Reedy 3900 low profile battery though. So if you add just the AE Ti screw kit & light weight body you will easily be able to run a full sized battery and the brass C mount and still be under weight.
