    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 06-28-2016, 05:01 PM   #991
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
The shock info should be in the wiki
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-28-2016, 06:55 PM   #992
RCBuddha's Avatar
Trader Rating: 33 (100%+)
http://www.redrc.net/2016/06/jconcep...tective-sheet/
RCBuddha is offline   Reply With Quote
Old 06-28-2016, 06:55 PM   #993
Trader Rating: 18 (100%+)
I'm planning to build my B6D with the machined shock bushings and machined shock pistons.
For the bushings I'm using AE 91494, but for the Pistons I've been debating between the AE machined and the Schelle. I'm leaning twards Schelle because they are sold in packs of 2 while the AE pistons come per 4 pack (I'm planning to start with the kit setup of 2x1.6 & 2x1.7). Any reason why the AE machined Pistons would be better than the machined Pistons from Schelle?
AMessy is offline   Reply With Quote
Old 06-28-2016, 06:57 PM   #994
RCBuddha's Avatar
updated the front page and the wiki. As a reminder, the wiki can be edited by anyone, so if you see something that should be up there, add it!
Old 06-28-2016, 07:01 PM   #995
B6 Set-up sheets are posted:
https://www.teamassociated.com/cars_...anuals_setups/
To finish first, you must first finish.
B6
I get my rug burns at Northwest Hobbies.
_danimal_ is offline   Reply With Quote
Old 06-28-2016, 07:03 PM   #996
For the bushings I'm using AE 91494......
The car comes with the machined bushings.
Edit: sorry, I see you mean the machined spacers.
Sean B. is offline   Reply With Quote
Old 06-28-2016, 07:31 PM   #997
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
I thought it came with machined Pistons?
RC*PHREAK is offline   Reply With Quote
Old 06-28-2016, 08:22 PM   #998
not according to the manual
Old 06-28-2016, 08:26 PM   #999
I thought the same based on some early AE employee Q&A sessions I saw online, but like Wildcat notes above the manual says differently.
Old 06-28-2016, 09:10 PM   #1000
Originally Posted by ray_munday View Post
I spoke with Kody and it doesn't fit the stand up gearbox. I received my kits yesterday and have the 12g brass c. Will be testing outdoors this weekend.
Ray
Let me know ho it compares to a B5M with your setup!
man1ac is offline   Reply With Quote
Old 06-28-2016, 10:44 PM   #1001
willbvegas's Avatar
Wink Went with the B5m
Originally Posted by JsK View Post
Should be an awesome car at 702. Our local track went from dirt to astro.
I went with the B5m. I actually bought two. One for my son and I both. A little birdy told me that they might actually be coming out with a b6 conversion kit. Heard it may be coming in November or early next year. Plus it was too good of a deal to pass up. $500 for two team kits and all electronics included. Except for receiver and radio which I already have.
willbvegas is offline   Reply With Quote
Old 06-28-2016, 11:16 PM   #1002
Suspended
Trader Rating: 61 (100%+)
No, they won't be. The entire car, from the shocks to every single piece of plastic is different.
The ONLY shared parts are few. Front axles, some of the bearings and a few others are the same.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-29-2016, 12:01 AM   #1003
JAE
Trader Rating: 26 (100%+)
Pretty sweet deals on these b5m's. Couldn't come close to finding something of this quality walking into a hobby shop and picking up 2 race ready buggies for a father and son. Congrats
JAE is offline   Reply With Quote
Old 06-29-2016, 12:51 AM   #1004
Maybe a kit to convert a B6D, to a B6 and vice-versa. But a B5M to a B6... nope. Possibly a B6 gearbox conversion for the B5M, but that's doubtful too.
B6
Old 06-29-2016, 05:06 AM   #1005
Johnn27's Avatar
Trader Rating: 69 (100%+)
Default Rear shocks
Originally Posted by mx836 View Post
I ordered kashima shock bodies for my b6d. Don't have either yet, but just discovered that the rears are supposed to be 27.5 mm (same as truck fronts) instead of the 31mm that fit the b5m. Bummer, because I ordered what fit the b5m. Had no idea they changed the shock body length and I feel like I've read plenty on this car already. At least they both take the same shafts from what I can tell in the manuals. Just a little warning for those that are looking to get the kashima shock bodies. You will have to run the optional 91666 rear shock tower with the 31mm shock bodies.
Just get the longer rear shock tower and you can run the b5 rear shocks. I believe the part number is listed s couple pages back .
Johnn27 is offline   Reply With Quote
