    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 06-27-2016, 09:01 AM   #946
Instruction manual is up
https://www.teamassociated.com/pdf/c...B6D_manual.pdf
Sean B. is offline   Reply With Quote
Old 06-27-2016, 10:07 AM   #947
Starting to believe now, LOL.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 06-27-2016, 10:51 AM   #948
Derry's Avatar
Trader Rating: 27 (100%+)
I thought I was looking at an Rb6 manual for a sec... Front end looks very similar. Only starts to look different when you get to the tranny parts.
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 06-27-2016, 12:04 PM   #949
Mason's Avatar
What is the B6 trailing steering set at? 3 or 4 ? I thought I saw in a video it was set at 4 but I cannot find that video, nor is it in the wiki here.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 06-27-2016, 12:27 PM   #950
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
+4 mm trailing
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 06-27-2016, 03:19 PM   #951
richmtb01's Avatar
Just posted my unboxing of the B6d if you wanna check it out:
https://www.youtube.com/watch?v=XBfzKxmoKDA
Also a new Blog post with additional photos:
http://www.thercnetwork.com/rc-cars/b6-b6d-2wd-buggy/
AKA
The RCNetwork on YouTube
richmtb01 is offline   Reply With Quote
Old 06-27-2016, 03:23 PM   #952
La parts house shows 1 instock and yeasterday it said 2
tlrky is offline   Reply With Quote
Old 06-27-2016, 03:34 PM   #953
I thought these were coming with Kashima coated shock bodies ?
sgtlt is offline   Reply With Quote
Old 06-27-2016, 03:35 PM   #954
Negative. If you have a b5m with the fox shocks they make a rear tower so you can use them on the b6
Old 06-27-2016, 03:40 PM   #955
Suspended
Trader Rating: 61 (100%+)
Only the D? Aren't you in Cali?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-27-2016, 03:42 PM   #956
I see now. I was mixed up with the Tc7 road car. I have been looking at both cars, lol.
Old 06-27-2016, 03:45 PM   #957
DRJVogel's Avatar
Just watched it. Rich, great job as usual. Thanks.
near Grass Valley, CA --- let's bash
DRJVogel is offline   Reply With Quote
Old 06-27-2016, 04:30 PM   #958
brian cox's Avatar
Trader Rating: 54 (100%+)
I think that is just a pre-order-
Team Orion---Bradley Fine Line Design---AKA
brian cox is offline   Reply With Quote
Old 06-27-2016, 04:50 PM   #959
Hey rich
I sub to your channel for a long time now and you're a very positive guy when it comes to all of your unboxings and reviews which is great but I'm wondering are there any downfalls you have noticed so far? For example like the quality control etc.
I don't think u built it yet so I'll stay tuned but let us know what you think both good and bad.
Keep the videos coming!
Slashn77 is offline   Reply With Quote
Old 06-27-2016, 05:29 PM   #960
richmtb01's Avatar
Originally Posted by Slashn77 View Post
Hey rich
Thanks! Everything looks great so far, but you have seen what I have seen. I'm starting the build tonight. One thing has me worried - if you saw the photos on the blog on my website - the upgrade parts have a totally different labeling system than the old school AE little stickers they put on bags. Almost like the upgrades were added at a different facility. I'm sure it's good, but just different from what I've seen. Also, no wheels. From what I've heard, it looks like AE is putting together s small kit for a lay down tranny for the B6d guys if the traction gets high (on clay especially). That should be out soon.
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Kremzeek, team green
