    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 06-26-2016, 06:23 AM   #931
Originally Posted by JsK View Post
AstroTurf is everything clay promised but never delivered. Clean,consistent,less labor intensive and more fun.
The track is not as flat as it looks and there is some interesting traction issues with the grain of the turf thats keeping people on there toes.
Not all turf is created equal.. When our turf was brand new I was heavily annoyed at how low grip it was..,, oddly enough a track down the road ordered the same turf and immediately way more traction was available... Plus every track change results in low traction till the lines are broke in. Guys are always going back and forth between the mini pins and the mini spikes depending on the track lay out. Dirt guys that think turf is just a joke and it's like a video game need to try it to understand it's not as high grip as people think... Plus, the fast guys run new tires because it's disastrous with worn out tires on turf.
dsms4ever is offline   Reply With Quote
Old 06-26-2016, 07:42 AM   #932
Suspended
Trader Rating: 61 (100%+)
Originally Posted by racer1812 View Post
I took the time to go back and find Sockets post, I don't see an issue with it. It's a simple short answer.
And honestly, it was nicer than most of his posts..
I hadn't laughed out loud in awhile, but that did it.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-26-2016, 11:14 AM   #933
Cridd's Avatar
Trader Rating: 16 (100%+)
Sometimes socket just needs a wrench or he gets bitchy
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 06-26-2016, 11:15 AM   #934
Suspended
I have raced once in the last 5 weeks.
And my next summer course and vacation are promising I won't race again for another 5 weeks...
Then fall semester starts...
Old 06-26-2016, 11:19 AM   #935
Cridd's Avatar
So you have a reason....what until you have a wife kids and work. RC for life!
Chris
B6D / T5M / SC5M
Old 06-26-2016, 11:20 AM   #936
Suspended
But we do finally have a new track coming!
Old 06-26-2016, 11:21 AM   #937
Suspended
I have a kid and a wife...
Old 06-26-2016, 11:21 AM   #938
Cridd's Avatar
Had my B5 on shelf so when B6 gets here it is like a honeymoon with buggy again, been taking T5 and SC5 out.
Chris
B6D / T5M / SC5M
Old 06-26-2016, 11:25 AM   #939
Cridd's Avatar
Ouch, I see said blind man. Toss buggy in closet!!
Chris
B6D / T5M / SC5M
Old 06-26-2016, 11:43 AM   #940
If it wasn't for 4-10's I'd never see the track. 3 kids and a wife plus an auto detailing side business. Choose between earning extra money, mountain biking, dirt biking or Rc practice. This summer is probably out for Rc! And yet I'm still awaiting that b6!!!
Old 06-26-2016, 12:26 PM   #941
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
Originally Posted by RCBuddha View Post
FREQUENTLY ASKED QUESTIONS AND ANSWERS
Q: How can I fit my B5M diffs in my B6/D?
A:The B6 diffs are 2mm wider (1mm per side). The new part number for the gear diff includes the needed spacers so you can run the B5 series gear diff in the B6. They are just using the rear axle spacers they made for when using the +4 C/D mounts on the B5. The small spacers are not needed.
are those spacers available separately? part #?
RC*PHREAK is offline   Reply With Quote
Old 06-26-2016, 12:34 PM   #942
AZJP's Avatar
Trader Rating: 20 (100%+)
Search cva shim set on amain.
AZJP is offline   Reply With Quote
Old 06-26-2016, 01:17 PM   #943
RC*PHREAK's Avatar
thanks!
Old 06-26-2016, 06:06 PM   #944
Suspended
Originally Posted by RCmenace View Post
Anybody try this yet?
Try what?
Old 06-26-2016, 06:09 PM   #945
That's a lot of work, normally we just cut them with body scissors. They are also available in a premount.
JConcepts offers a narrow front wheel for the B5 /6.
MX304 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
