    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree286Likes
Old 06-25-2016, 04:39 AM   #901
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Default Turnbuckles
Are the turnbuckles the same length as the b5's? Can I use my ti turnbuckles from my b5 on my b6? Thanks
VA Beach
F18engineguy is offline   Reply With Quote
Old 06-25-2016, 06:37 AM   #902
stegger's Avatar
Not all of them check here.
https://www.rcten.com/threads/b5-b6-...ty-list.20367/
stegger is offline   Reply With Quote
Old 06-25-2016, 07:09 AM   #903
They should work fine. If anything they would be about a 10th of an inch longer.
Sean B. is offline   Reply With Quote
Old 06-25-2016, 07:22 AM   #904
Suspended
Trader Rating: 61 (100%+)
Originally Posted by JsK View Post
Should be an awesome car at 702. Our local track went from dirt to astro.
Indoor or outdoor? What astro did they use?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-25-2016, 09:38 AM   #905
Finalist's Avatar
Did you preorder anywhere? Tower and Amain are pretty good about sending emails.
Yes,
My LHS who gets their supplies/distribution from HRP. HRP has contacted my LHS with some good news.
Finalist is offline   Reply With Quote
Old 06-25-2016, 09:48 AM   #906
Finalist's Avatar
Default Will B5m turnbuckles work on B6
Originally Posted by stegger View Post
The b5m uses 48mm for all six and the b6 uses 48mm for all six.
Old 06-25-2016, 11:02 AM   #907
willbvegas's Avatar
Thanks. I'm hoping so. Just don't know which receiver and transmitter I should go with. Any suggestions anyone? And the support here is mostly Sanwa, Futaba and a little FlySky
willbvegas is offline   Reply With Quote
Old 06-25-2016, 11:43 AM   #908
Cridd's Avatar
Trader Rating: 16 (100%+)
Sanwa is good for me
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 06-25-2016, 11:59 AM   #909
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
the sanwa MT4s is more than enough radio for club racers. The MTS looks good, but unsure how available they are yet.
Looks like Amain carries the mts.
https://www.amainhobbies.com/sanwa-m...31973a/p500043
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-25-2016, 12:00 PM   #910
DRJVogel's Avatar
Me too. I am impressed by the Sanwa radio.
near Grass Valley, CA --- let's bash
DRJVogel is offline   Reply With Quote
Old 06-25-2016, 12:11 PM   #911
bilster44's Avatar
[QUOTE=Wildcat1971;14580237]the sanwa MT4s is more than enough radio for club racers. The MTS looks good, but unsure how available they are yet.
And...if one is so inclined, you can even get a drop neck for this transmitter to make it really ergonomical! (How's it going Leigh?)
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 06-25-2016, 01:03 PM   #912
[QUOTE=bilster44;14580245]
Good. You using the mt4 drop down?
Old 06-25-2016, 02:03 PM   #913
bilster44's Avatar
[QUOTE=Wildcat1971;14580281]
Sure do
Old 06-25-2016, 03:47 PM   #914
Cridd's Avatar
Kids have the same one, very nice.
Chris
B6D / T5M / SC5M
Old 06-25-2016, 04:09 PM   #915
DRJVogel's Avatar
That "drop down" is pretty sweet.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
