    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 06-23-2016, 01:40 PM   #871
Mason's Avatar
Originally Posted by dsms4ever View Post
I drove my b5m for a year without breaking anything but wings...learn how to drive and it will save you a lot of wasted money and time on replacement parts....
Thanks for the Pro Tip. Unfortunately, I can't help other peoples' driving.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is online now   Reply With Quote
Old 06-23-2016, 06:52 PM   #872
Originally Posted by Wildcat1971 View Post
you let people take off work during a major release...shame shame
Lol
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 06-23-2016, 07:14 PM   #873
willbvegas's Avatar
Originally Posted by Socket View Post
Up at the top, there is a wiki. Read it.
Your parents raised you with manners. From birth. Use them.
willbvegas is offline   Reply With Quote
Old 06-23-2016, 07:20 PM   #874
willbvegas's Avatar
Originally Posted by Mason View Post
Alright, now let's get down to the brass tacks.. Are parts only production runs occurring yet? Will parts be available in the hobby shops when the kits arrive? As we all know every car release of every kind has the same problem. Joe HotShoe has to buy 2 kits to have parts on hand for the first month in case he breaks an arm, tower, etc. because even with LHS' having items on order or even backorder they are not available. John Newbie buys a kit, comes out to the track and ends his race day before running a qualifier because he broke in practice. What good does it do me to have a car, break something, and then not be able to replace it? This is the Number 1 reason why I never pre-order a kit or heck, even consider buying one until I see parts on the wall. So have we changed our ways this time around?
Not too sure. However, I did check with 702 Raceway here Las Vegas and they said they will actually have parts in the shop before you will even get the car. Like next week or the following. The owner said most hobby shops will have the parts before the car comes out because they are given the list of parts and order recommendations from Associated as merchants so that they can support the car when it is released. Hope his helps.
Old 06-23-2016, 07:25 PM   #875
willbvegas's Avatar
Originally Posted by Mxer210 View Post
Yep there are only a few differences. Pretty sure its on the first page but I'll go over them real quick.
Everything is the same but:
B6-Gear diff, B6D-Ball Diff
B6-Laydown Transmission, B6D-Stand up 3 gear Trans (Idler gears are different also)
B6-Gullwing front Arms/Tower, B6D Flat front arms/Tower
you can buy all of those parts separately and convert either one to either the B6 or B6D for fairly cheap.
Thank you very much for the quick and kind reply. It's much appreciated. Especially on here. Some people seem to think it is okay to be sarcastic to someone they've never met.
Old 06-23-2016, 07:41 PM   #876
DRJVogel's Avatar
I agree. It doesn't take much more time to word a post that is kind and well written.
near Grass Valley, CA --- let's bash
DRJVogel is offline   Reply With Quote
Old 06-23-2016, 07:50 PM   #877
JsK
JsK's Avatar
The wiki is there so people don't have to ask and awnser the same questions over and over. Socket is pointing out something you might not have been aware of. A little direct yes, but not really rude. Maybe after you have more than 7 posts and spent hours building the wiki only to have people ask the same things over and over you will understand.
JsK is offline   Reply With Quote
Old 06-23-2016, 08:53 PM   #878
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Just added the B6 to B6D conversion to the front page.
RCBuddha is offline   Reply With Quote
Old 06-23-2016, 10:33 PM   #879
Kegman21's Avatar
Parts will be nice in the shop but I still ordered a lot of parts to have on hand just in case Duane doesn't get everything we need at 702.
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Old 06-24-2016, 05:14 AM   #880
Suspended
Trader Rating: 61 (100%+)
Hello, I have worked tirelessly to compile data and create a wiki for the brand car I'm currently running.
So has rc Buddha for the b6 and b6d. Neither of us are factory drivers or are compensated in any way for our efforts.
I'm not asking for a thank you, I'm asking that instead of posting a recycled question, please grab a big glass of water and a note pad, and read the wiki. It's there for your use, my use, and everyone elses. However, it's not worth anything if you don't use it.
If you don't like my responses, I'm sure you can be a big boy and ignore it. I added a smiley there to lighten my comment, however it still stands, use the wiki.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-24-2016, 06:25 AM   #881
compRacer's Avatar
Thanks 'RCBuddha' & 'Socket' for all the great information you compile in one location which helps all us weekend warriors!
I dont know half of you half as well as I should like; and I like less than half of you half as well as you deserve.
compRacer is offline   Reply With Quote
Old 06-24-2016, 07:09 AM   #882
Manuals should be up on the site today (:
Mxer210 is offline   Reply With Quote
Old 06-24-2016, 08:06 AM   #883
AZJP's Avatar
Trader Rating: 20 (100%+)
:clap:
AZJP is offline   Reply With Quote
Old 06-24-2016, 12:00 PM   #884
For a fact or are you just randomly saying they "should" be as in you'd like them to be?
dsms4ever is offline   Reply With Quote
Old 06-24-2016, 12:14 PM   #885
Suspended
Rc Car Action got their press kits today.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
