    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 06-22-2016, 03:15 PM   #841
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Sean Cochran View Post
I am not the person to confirm shipping details but this statement is not true,
"1 Week from now the first shipments get on the boat in Asia port "
aeRayls statement is more correct
Adam = aeRayles.
So I am correct in believing him?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-22-2016, 03:28 PM   #842
AE-Reedy
Originally Posted by Socket View Post
Adam = aeRayles.
I misunderstood then I thought you were agreeing with 190. Sorry
Yes Adam's statement is correct.
Sean Cochran is offline   Reply With Quote
Old 06-22-2016, 03:33 PM   #843
Suspended
Happy to hear.
Old 06-22-2016, 03:39 PM   #844
Hey hopefully sooner than later. But I am just going with watching all the past releases in the past year and PDF manuals got on the website about 2 weeks before kits got to Tower, AMain, Distributors and their dealers.
Also parts seem to beat the kits to these major online retailers and although I have not tracked the parts, I did not seem to notice them stocked up much.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 06-22-2016, 04:05 PM   #845
AE-Reedy
AE does not have an "official" time line that things happen.
Kit manual not up could be an oversight, not sure. They could have posted it a month ago if they wanted. I will inquire about this.
Parts, yes they "normally" do beat the kits, but in this instance everything is kinda hitting at once.
Old 06-22-2016, 05:04 PM   #846
Suspended
I'm going to go out on a limb, and assume you don't know who Sean is.
Old 06-22-2016, 05:44 PM   #847
Yes talented multi-class sponsored RC racer that runs the Reedy division?
Have the manuals up tomorrow by 6PM EST and I will believe boys.
Old 06-22-2016, 06:40 PM   #848
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Thank you! Guys and girls around here are patiently waiting.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-22-2016, 07:24 PM   #849
Originally Posted by fullsyzz View Post
b6 bodies are available on tower right now
http://www3.towerhobbies.com/cgi-bin...&P=WR&I=LXGCNV
shdwboxn is offline   Reply With Quote
Old 06-22-2016, 07:28 PM   #850
Jmuck69's Avatar
Jmuck69 is offline   Reply With Quote
Old 06-22-2016, 08:10 PM   #851
B44
B44's Avatar
I know Sean
B44 is offline   Reply With Quote
Old 06-23-2016, 12:14 AM   #852
willbvegas's Avatar
Default Hasn't been asked from a newb yet
I have a question. This may sound stupid. Can you convert the B6 to a B6D? I know you can buy the extra parts to convert the B6D to a B6. But does it work the other way around as well?
willbvegas is offline   Reply With Quote
Old 06-23-2016, 12:56 AM   #853
Yep there are only a few differences. Pretty sure its on the first page but I'll go over them real quick.
Everything is the same but:
B6-Gear diff, B6D-Ball Diff
B6-Laydown Transmission, B6D-Stand up 3 gear Trans (Idler gears are different also)
B6-Gullwing front Arms/Tower, B6D Flat front arms/Tower
you can buy all of those parts separately and convert either one to either the B6 or B6D for fairly cheap.
Mxer210 is offline   Reply With Quote
Old 06-23-2016, 05:38 AM   #854
Suspended
Up at the top, there is a wiki. Read it.
Old 06-23-2016, 07:09 AM   #855
Mason's Avatar
Alright, now let's get down to the brass tacks.. Are parts only production runs occurring yet? Will parts be available in the hobby shops when the kits arrive? As we all know every car release of every kind has the same problem. Joe HotShoe has to buy 2 kits to have parts on hand for the first month in case he breaks an arm, tower, etc. because even with LHS' having items on order or even backorder they are not available. John Newbie buys a kit, comes out to the track and ends his race day before running a qualifier because he broke in practice. What good does it do me to have a car, break something, and then not be able to replace it? This is the Number 1 reason why I never pre-order a kit or heck, even consider buying one until I see parts on the wall. So have we changed our ways this time around?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Currently Active Users Viewing This Thread: 9 (2 members and 7 guests)
christopher_2, team green
