    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 06-20-2016, 10:01 AM   #811
BRSracing's Avatar
Trader Rating: 53 (100%+)
Originally Posted by HYPA View Post
What would be the advantage of a laydown tranny in a B6D on a dirt surface (if any)?
one big advantage is your car looks more like the pro drivers
BRSracing is offline   Reply With Quote
Old 06-20-2016, 10:09 AM   #812
Brit_racer's Avatar
Trader Rating: 130 (99%+)
some B6 bodies in stock at Team Associated. I ordered three to airbrush and sell. Do you guys prefer the lightweight bodies or the regular ones?
Rc10B5m, Serpent SRX4, Xray XB2, T5m, RC8B3e, RC8T3e
Innovation Raceway
Brit_racer is offline   Reply With Quote
Old 06-20-2016, 11:52 AM   #813
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
the b6 gear diffs were in stock this morning
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-20-2016, 12:16 PM   #814
Trader Rating: 20 (100%+)
Yep, and I ordered gear diff, bodies, and wings!! Come on car now!! At least we will have some painted bodies ready!!
Randy
RandyJones is offline   Reply With Quote
Old 06-20-2016, 12:20 PM   #815
Interested in how you guys will build.
I am thinking...
Team Orion Motor and ESC
Savox servo
AKA tires
KA Motorsport is offline   Reply With Quote
Old 06-20-2016, 12:43 PM   #816
dirt42fan's Avatar
Trader Rating: 135 (100%+)
Originally Posted by bds81175 View Post
You want on power steering, reduce front droop. Why are you running a 4 gear on turf?
hmmmm... I always thought it was the opposite?
Tuning with Droop
Typically, less Droop reduces body roll. Less in the rear will free up the rear a bit, giving more steering. More Droop in the front is good for better on-power steering.
8IGHT 3.0 Tuning Tips
More droop (travel) in the front will have more on-power steering and allow the buggy to
roll more on the rear when on throttle.
"Never apologize for hard racing" Scott Bloomquist
dirt42fan is offline   Reply With Quote
Old 06-20-2016, 01:56 PM   #817
I am thinking...
Savox servo
AKA tires
Sounds good depending on which Savox ur thinking of and also Orion stuff is great but is also the most expensive too expensive IMO even compared to other A brand options which are just as good and are a bit less money
Slashn77 is offline   Reply With Quote
Old 06-20-2016, 02:10 PM   #818
Jmuck69's Avatar
I am thinking...
Savox servo
AKA tires
I run Orion ESC and motor and the smoothest and most trouble free.
Savox servos i have not run but have heard of issues with them. I personally run Airtronics 94661 servo (Sanwa ERS-961) and is flawless. Different companies tire compounds are drastically different but really like ProLine with JC second. AKA have never had much luck getting them to work. Proline tires sauced with yellow liquid wrench is money!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 06-20-2016, 07:51 PM   #819
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Changed the wiki, let me know if you guys like that, or want something different.
RCBuddha is offline   Reply With Quote
Old 06-21-2016, 06:29 PM   #820
SuperBoots's Avatar
I am thinking...
Savox servo
AKA tires
Hobbywing xr10 Justock esc
Trackstar 17.5 v2
undecided on servo
Dirt Webs gold compound tires
-Dan
RC10B4.2, RC10T4, SC10
Find me at T.R.C.R.
SuperBoots is offline   Reply With Quote
Old 06-21-2016, 06:34 PM   #821
Trackstar 17.5 v2
undecided on servo
Thank will save him a lot of money but they don't have the support/ Warrenties that Orion tekin etc would have
Old 06-21-2016, 06:48 PM   #822
Jmuck69's Avatar
B6 kits have arrived at AE!
This is off AE's Snapchat
B6D | B64D
Old 06-21-2016, 07:02 PM   #823
Would be nice, likely those are production kits for initial build check of the exact kit release the public will see or rest of team drivers of certain levels to be supplied.
Not for public consumption. Still 3 to 4 weeks away likely.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 06-21-2016, 07:25 PM   #824
Jmuck69's Avatar
Wow...buzzkill
B6D | B64D
Old 06-21-2016, 07:40 PM   #825
Moderator
bds81175's Avatar
Tuning with Droop
This is a two wheel drive car. And on power implies coming out of the corner on power. The chassis isn't going to roll any further at this point. It will be transferring weight from the front to the rear. Decreasing the front droop reduces the amount of weight that will transfer off the front tires. Give it a shot. It definitely works. It's one of my more common adjustments.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
cbazq271, Mi4cxl
