    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 06-17-2016, 08:21 AM   #796
Finalist's Avatar
Originally Posted by Wildcat1971 View Post
the b6 has lower rear shock towers....so the weight of the shocks is lower. lower cg
I know the CG is lower. Yesterday when AE released the new B6 rear tower that allows b5m rear shocks to be used I got the impression there is another benefit to the b5m shocks for bumpy tracks besides higher CG. They stated as answer to my Q that the B5m shocks have more volume as if that is a benefit. What benefit does more volume have besides using up more shock fluid?
Finalist is offline   Reply With Quote
Old 06-17-2016, 08:31 AM   #797
Suspended
Trader Rating: 61 (100%+)
We're still not clear on the impact of more volume for the same droop and shock throw.
Maifield has played with it a TON on the 22 2.0, as well as in 1.8th scale. I haven't been given a definitive answer on what it helps.
Fluid displacement and volume are two unknowns that if I had time, would love to collect more data on.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-17-2016, 08:43 AM   #798
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Lots of factors, and unsure if they apply to 1/10. Perhaps more weight over the rear for grip? I have no desire to read or research fluid dynamics for rc cars. I plan to just use the shocks that come with the kit.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-17-2016, 08:49 AM   #799
rvrslt1's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Kraig View Post
Ah ok. I will admit I didn't read if he posted which car he was getting. So I thought I would mention which one would work on which car.
Would be running 17.5 with the lay down trans. Just want to make sure I get the correct part when they become available. Thanks again for all the help!!
rvrslt1 is offline   Reply With Quote
Old 06-17-2016, 11:13 AM   #800
Finalist's Avatar
Just thought of a possible performance gain/loss for 31mm versus 27.5mm rear shocks... You get different amounts of thread options to adjust ride height? 31mm allows for the spring collar to be threaded up higher???
Old 06-17-2016, 12:08 PM   #801
Suspended
Right. But the real question is what impact does the change in fluid displacement have on the handling of the car.
Sure, more droop and travel can be calculated.
Old 06-17-2016, 12:47 PM   #802
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Originally Posted by Rhett McNair View Post
Proline is about to release a body for the car also
Is it going to be a predator and do you know when it's going to be available ?
VA Beach
F18engineguy is offline   Reply With Quote
Old 06-17-2016, 01:10 PM   #803
You can use the different height cups as well.
Old 06-17-2016, 02:02 PM   #804
Kegman21's Avatar
For Carpet and high bite we run a higher spring rate in the rear to assist with turning and jumping. To loose and your ass hits the jump and your nose is pointing straight down. And when you land you end up breaking things due to your ride height being so low.
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Old 06-17-2016, 02:40 PM   #805
Finalist's Avatar
Yes, but you can change spring rates with either 31 or 27.5. Having a shorter shock body (27.5 vs 31mm) isn't going to limit nor increase your spring choices.
Old 06-18-2016, 06:06 AM   #806
shadowracer24's Avatar
May have more to do with lowering the vcg of the car more than anything.
shadowracer24 is offline   Reply With Quote
Old 06-18-2016, 06:44 AM   #807
honestly, the best way to see what it does, is you buy the tower and shocks and try it. same with the laydown, buy and try. asking on here is very limited in its usefulness.
Old 06-19-2016, 07:39 PM   #808
Canada 95's Avatar
Default tall tower
I can see a few positives of this taller tower,
1-can use your rear FOX shocks from your B5m
2-will make it easier for someone to fit a B6 gearbox to a B5m
3-longer bodies mean piston doesn't enter the air pocket in top of shock.
I am a professional. At the circuit I am calm. At home I am very different.
Canada 95 is offline   Reply With Quote
Old 06-20-2016, 04:28 AM   #809
HYPA's Avatar
What would be the advantage of a laydown tranny in a B6D on a dirt surface (if any)?
HYPA is offline   Reply With Quote
Old 06-20-2016, 07:09 AM   #810
Suspended
More corner speed at the expense of rear bite.
Currently Active Users Viewing This Thread: 10 (3 members and 7 guests)
3n90t, Still Bill
