    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 06-08-2016, 07:56 AM   #706
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by dsms4ever View Post
I looked through the parts compatibility list. and it looks like the bones will work from a b5m in the B6. Just wanted to make sure that if I held onto my mip pucks/ball diff that I could use it in the b6? Thanks. Will the bones work only or will the whole assembled axle work?
The diff is new. Not positive that your pucks will work. Only way to find out is to try it when you get the car.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 06-08-2016, 08:26 AM   #707
They made a new part number for the b6 ball and gear diff.... But the gear diff parts sold separately all are compatible with the b5m...that's odd, furthermore the b6 ball diff out drives don't list as being compatible, but the cva axles and bones are compatible. A little bit of deduction based reasoning tells me that the b5m ball and gear diff will work perfect in the b6...can anyone prove me wrong?
dsms4ever is offline   Reply With Quote
Old 06-08-2016, 08:28 AM   #708
The b6 does come with the aluminum gear diff cover which is cool...
Old 06-08-2016, 08:29 AM   #709
Super Moderator
ball diff: It will work with shimming. The outdrives have changed.
Old 06-08-2016, 10:47 AM   #710
Jmuck69's Avatar
Originally Posted by Mason View Post
4 gear testing already? self-made or authentic AE test?
It's in the parts section of the B6D page on AE's website.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 06-08-2016, 11:07 AM   #711
Kegman21's Avatar
Spencer was running the aluminum stearing rack on his B6 so that seems like an upgrade that should help.
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Old 06-08-2016, 12:14 PM   #712
BRSracing's Avatar
Trader Rating: 53 (100%+)
AE is teasing something new on snap chat looks like a new motor and something else. Maybe a ESC?
BRSracing is offline   Reply With Quote
Old 06-08-2016, 12:57 PM   #713
A new Reedy motor like Mach 4 or something? Or is it AE branded?
I wouldn't mind a new esc as long as they don't raise the price up with the Orion stuff
Slashn77 is offline   Reply With Quote
Old 06-08-2016, 01:31 PM   #714
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
maybe a new 1000z/motor combo
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-08-2016, 02:01 PM   #715
Trader Rating: 20 (100%+)
Two new shorty servos were announced today!!
Randy
RandyJones is offline   Reply With Quote
Old 06-08-2016, 02:13 PM   #716
I saw that. the snap chat really looked like a motor....
Old 06-08-2016, 02:27 PM   #717
Whats AE's snapchat?
superbikemike is offline   Reply With Quote
Old 06-08-2016, 03:45 PM   #718
Kegman21's Avatar
snapchat app
Old 06-08-2016, 05:49 PM   #719
Well that's helpful. What is AE's username on snapchat?
Sean B. is online now   Reply With Quote
Old 06-08-2016, 06:13 PM   #720
I don't have snap chat so any specifics on the new servos as far as speed and torque?
Currently Active Users Viewing This Thread: 9 (2 members and 7 guests)
Cday, Evoking1230
