    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 08-15-2017, 02:08 PM   #7171
I'm thinking about getting a new buggy as parts are easier for me to get for the B6's. Apart from the electronics, is there any difference between the B6D and the Club Racer?
stuffandthat is offline   Reply With Quote
Old 08-15-2017, 02:12 PM   #7172
Krio's Avatar
Trader Rating: 150 (99%+)
The shock towers aren't carbon fiber, but that doesn't matter. 99% of everything else is identical, making the Club Racer a great deal if the included electronics suit your needs.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 08-15-2017, 03:53 PM   #7173
What's better for the shock towers? Carbon or the fiberglass? I'm not too keen on the fixed timing motors so I might be better off going for a B6D.
Old 08-15-2017, 04:20 PM   #7174
Krio's Avatar
They both have good and bad attributes. Carbon are more rigid and a tad lighter, but are more prone to breaking.
www.kriostasis.com
Old 08-16-2017, 01:36 AM   #7175
Hi all,
Can anyone tell me what's going with B6 gear diff outdrives? Seems to be a supply issue in the UK. Rumour has it that AE are working on a new gear diff?
88davidw is offline   Reply With Quote
Old 08-17-2017, 03:57 AM   #7176
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
I picked up one of both the 13.5 and 17.5 FT motors. Neither are slow. Don't be scared to give it a shot. Great motor.
Jon Carlson is offline   Reply With Quote
Old 08-17-2017, 08:11 PM   #7177
tsair's Avatar
Anyone know if you can run B5/B6 V2 slipper hubs on a B4.x? It looks like the pads are the same, but are the hubs interchangeable?
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is online now   Reply With Quote
Old 08-18-2017, 10:30 AM   #7178
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Yes, they are the same.
tsair likes this.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-18-2017, 05:47 PM   #7179
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Default Neat!
Red RC ? RC Car News Team Associated Factory Team Ball Cup Wrench
RCBuddha is offline   Reply With Quote
Old 08-18-2017, 06:38 PM   #7180
serpentracer1's Avatar
Send a message via AIM to serpentracer1
Well I havnt been racing in 4yrs and ran losi before I just pulled the trigger and got the B6D to start running again I havnt drove an associated car since the gold chassis and the org B1 looking forward to running again. Running mod starting with box setup and going from that point to get a handle on this mid motor craze. I got a few option parts cblock 25g D block I have plenty of springs also ordered laydown trans for when my tracks traction comes up in the winter with all the people racing .Is there anything else I should be looking to get thats functional and not bling that I might need later once I get used to running again. Also what chargers are good to have Im looking for one that reads the ir Thanks
DAVE (THE SNAKE) Rasnake
Original Mimi Wong Clan. M.W.C. For Life
Losi 22/Losi 8ight
Orion R10 Pro VST powered
serpentracer1 is offline   Reply With Quote
Old 08-18-2017, 06:42 PM   #7181
rubezzz's Avatar
Other than the laydown gearbox, is there anything else that needs to be added to the car to run it on astro?
rubezzz is offline   Reply With Quote
Old 08-18-2017, 08:54 PM   #7182
E-Mann's Avatar
Trader Rating: 24 (100%+)
If you are buying new the B6 comes with laydown gearbox. If you are converting from a B6D you will also need gear diff, springs, Gullwing (hard) arms, Gullwing carbon tower, carbon rear tower plus front and rear sway bars. Front brass bulkhead and the chassis weights will help get weight up to minimum.
T6 / B6 / B64 / B64D / XRAY XB4
Maclan / Savox / Airtronics
E-Mann is offline   Reply With Quote
Old 08-19-2017, 12:30 AM   #7183
rubezzz's Avatar
Exactly what I wanted to know, thanks e-mann
Old 08-19-2017, 01:04 AM   #7184
Trader Rating: 18 (100%+)
I'm having some issues with my rear axles. I run the schelle hubs and bmi inserts. I was running the hd axles and mip pucks (in 67mm length). I put the AE 67mm axle conversion on the car tonight and when I crank down on the wheel nut, the clamping hex moves and binds the drivetrain. I didn't have this issue before and don't have the problem on my truck or 4 wheel. Any ideas?
Chris Brown is offline   Reply With Quote
Old 08-19-2017, 06:40 AM   #7185
rubezzz's Avatar
Does anyone know what the part number is for the gull wing front arms to convert b6d to b6?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
