    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree286Likes
Old 05-31-2016, 07:06 AM   #661
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Yep... I would venture to say the gear diff would only be beneficial on carpet/turf.
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 05-31-2016, 07:44 AM   #662
aeRayls's Avatar
Originally Posted by Socket View Post
Many people are successfully running the laydown car on dirt.
Just sayin.
Yeah i agree but to buy the B6D and convert to the lay down is by far more economical than buying the B6 and other parts.
Most will not use the gear diff, gullwing arms and tower, they're great tuning options but most won't use them at all or even utilize them as an option.
aeRayls is offline   Reply With Quote
Old 05-31-2016, 08:38 AM   #663
You guys win...I changed my order to a D. Bastards...
-Ryan-
CTRJ is offline   Reply With Quote
Old 05-31-2016, 04:31 PM   #664
Could we also get the setup database added to the first page? Not much there now, obviously.
http://site.petitrc.com/setup/associ...tedRC10B6.html
boucher is offline   Reply With Quote
Old 05-31-2016, 08:50 PM   #665
What servo would your guys recommend ?
weedsnager is offline   Reply With Quote
Old 06-01-2016, 06:44 AM   #666
Suspended
Trader Rating: 61 (100%+)
Whatever one fits your weight, speed, and reliability needs.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-01-2016, 07:11 AM   #667
That helps narrow down my choices....thanks
Old 06-01-2016, 07:30 AM   #668
Suspended
It's more of a hint: Give us an idea of what you're after, then the suggestions can start. Also give an idea of budget before I start recommending KO propo stuff.
Old 06-01-2016, 07:35 AM   #669
I'm looking at the D version, for some light racing. I don't need anything fancy, just the most reliable servo that won't break the bank, I'd like to stay under $100
Old 06-01-2016, 07:50 AM   #670
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I'm looking at the D version, for some light racing. Budget would be under $100
I primarily look at the speed, torque and the voltage that the servo is rated at. Right now, I am at least looking for a speed of .10 seconds, torque of 100 ounce inches, at 6 volts. I say 6 volts because that is what my speed control b.e.c. is supposed to be able to supply.
Some speed controls only supply 5 volts and some receivers can't handle voltages above 6, but they are getting to be few and far between.
If you can share what radio system and speed control you are using we can let you know if there might be compatibility issues.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-01-2016, 08:03 AM   #671
Default Gear Cover for lay-down
I realize that there is no gear cover for the lay-down transmission because it was born from the carpet world, but those that will be running it in there B6D... Will there be a gear cover for the spur and pinion for those running in the dirt?
dustneyes is offline   Reply With Quote
Old 06-01-2016, 08:06 AM   #672
Jmuck69's Avatar
The laydown in the B6D will be used on tracks that seal the track or produce very little dust. No gear cover needed.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 06-01-2016, 08:18 AM   #673
That's very true. I run on an indoor damp clay track. The pinion and spur on my Tekno 410.3 seems to stay fairly clean. Thanks!
Old 06-01-2016, 08:19 AM   #674
Thanks for all your help....
I'll be using a spektrum radio and a Blackbox 800Z Zero-Timing ESC
Voltage Input: 7.4V, 2S LiPo
On Resistance: 0.0004
Continuous Current: 80A
Dimensions: 1.6 x 1.2" 0.74" (40.2 x 31.0 x 18.8mm)
Weight: 1.3oz (37g)
Motor Limit: 10.5T
SBEC: 6.0V/3A
Old 06-01-2016, 08:44 AM   #675
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
variety of good fast servos out there. I am fond of Futaba and hitec brand servos personally, but I have used some savox standard and low profile servos with my Hobbywing ESCs and no issues to report.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Currently Active Users Viewing This Thread: 7 (2 members and 5 guests)
cbazq271, Kalio
