    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree308Likes
Old 05-21-2016, 01:23 PM   #601
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Originally Posted by aeRayls View Post
As to which kit to buy, the way Brent explained it (which wildcat shared) is pretty spot on. To me it's this simple:
The only reason to buy the B6 is if you plan to run carpet or turf, that's it!
For any other surface including switching back and forth between dirt/turf/carpet etc buy the B6D and any parts to convert as it'll be cheaper and easier.
Well said. This will go on the front page in a few.
RCBuddha is offline   Reply With Quote
Old 05-21-2016, 02:27 PM   #602
tsair's Avatar
I think the only other reason is that so many people will be buying B6D's, there might be a run on laydown transmission parts for a while? Probably be less people trying to go the other way, so easier to get ball diff parts and front arm parts.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 05-21-2016, 05:38 PM   #603
RCBuddha's Avatar
That's why I ordered both kits. I might be able to sell my lay down at a premium.
Old 05-22-2016, 06:15 AM   #604
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
I'm just hoping to get the aluminum chassis insert for under my electronics. I can't wait to get the B6D built!
Jon Carlson is offline   Reply With Quote
Old 05-22-2016, 11:21 AM   #605
vabroom's Avatar
Okay, B6/D delayed anywhere from mid June to mid July. I hope at least they have the manual for download soon.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 05-22-2016, 02:35 PM   #606
Manuals go up on the website when the kits are on the boat leaving from China.
My guess is June 29th +/- 2 days.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 05-23-2016, 05:22 AM   #607
Where did you hear that?
Mxer210 is offline   Reply With Quote
Old 05-23-2016, 08:03 AM   #608
BRSracing's Avatar
Trader Rating: 53 (100%+)
I assume he is just guessing on the manuals..... AE said they would be up closer to the car arriving. The B5m manual was up like one day several weeks before the car arrived and then they took it down. The RC8 manuals were up after the car had been out for a bit so who knows.
BRSracing is offline   Reply With Quote
Old 05-24-2016, 08:29 AM   #609
I think people are still getting way too tripped up on nomenclature. Just think of the two kits as "starter packs". They're both the same freakin car, just with a different set of options in the box. Most of us are going to be running a combination of the two kits anyway. I can already see this is going to be my pet peeve of this chassis lol.
boucher is offline   Reply With Quote
Old 05-24-2016, 09:55 AM   #610
a1
if they hype it up and keep everything quite it creates better sales
a1 is offline   Reply With Quote
Old 05-24-2016, 10:29 AM   #611
Finalist's Avatar
First rule of hyping is to keep feeding the beast. AE better feed some new info this week or market exhaustion will set in and people will drift away. We're still looking at 2-6 weeks for the release... which is an eternity in social media marketing.
Maybe they'll talk about Spencer's new low profile Reedy servo in his B6 or release the B6 Manual soon?
Finalist is offline   Reply With Quote
Old 05-24-2016, 02:14 PM   #612
Yep that's drives these forums pre release but it pretty much has lost momentum because there is no new info (which can easily change)
I'd be interested in hearing about the servo! Manual seems too far away right now
Slashn77 is offline   Reply With Quote
Old 05-24-2016, 04:56 PM   #613
Cridd's Avatar
Trader Rating: 16 (100%+)
In this day and age almost needs to be released within a few weeks of being announced. Have the hype and test cars and pictures with those funny paint jobs like they do on cars then announce it with a sales date shortly after. The wedding is over time to get to the honeymoon and let the wheels hit the pavement.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-24-2016, 04:58 PM   #614
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
look at it this way, AE is giving people some time to sell their current cars and save for the new one. Imagine how people would lose their minds with a online release then 2 days later kits drop. Pandemonium I say. lol
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 05-24-2016, 05:12 PM   #615
Kegman21's Avatar
I would be happy with a firm release date.
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 14 (1 members and 13 guests)
Phillip F
