Team Associated B6 & B6D thread
#6091
+1 on heavier cars being easier to drive.
Running my B6 in stock I have always tried to get as close to 1500 as possible. On one of my last practice sessions the track owner (AE driver) put his money where his mouth is. He took both brass weights (69 grams total) from under his battery and said "put these in, adjust your ride height and see what you think." I couldn't see spending more money on weight as I was right at 1500 but he was right. I could run just as fast of laps, more consistently with the added weight.
#6092
#6094
#6095
Have you tried your existing setup/weight with a lower spring rate? That could have a similar effect without the handicap of the extra weight.
Back when lipo became popular, many guys setups called for as much a 6oz. added weight. After a while, the AE guys re-jigged the B4's setup and got it to work very well at 1500g.
#6096
Seems like you have a setup opportunity. Adding the weight and adjusting the ride height to suit should just slow down the car's reaction a little.
#6097
Part number is ASC91736 but I think I'm going to try things how JsK suggested and run without a sway bar and with the stock b6 setup.
I just spent most of today on putting everything in line with the stock setup and I think I'm ready to give it a whirl at the track.
Thanks for all the help everyone. I really appreciate it
#6098
- performance wise you will feel the rear more locked in mid corner and on power.
- the 0 refers to the toe-in of the blocks
- as the axle height isn't adjustable, they may not be suitable for turf / carpet where super low ride heights are used.
Ray
#6099
Hubs
[QUOTE=ray_munday;14869933]We use them on outdoor dirt. They are slightly stiffer and heavier than the kit plastic parts, also more durable. The axle height is equivalent to 0mm on the plastic parts.
Ray[/QUOTE
Would they help any or be any good on indoor clay tracks? The different tracks are medium, medium to high, or high bite traction. Some tracks are smooth, and some are smooth with some ruts. Usually using 21mm- 23mm ride heights.
Thank you very much!
Ray[/QUOTE
#6100
[QUOTE=rgrg2;14869952]
Unfortunately I don't get to run on that kind of surface, but from what I see the team guys in the US also use the alloy hubs on the rear of their B6. SO I would say yes.
Ray
Ray[/QUOTE
Ray[/QUOTE
Ray
#6101
I don't know if you're looking for a lightweight battery but I just got the new protect lihv 3600 battery and love it. Without any weights and the 25 gram c block my car was 1452 grams. Added the brass weight plates and nondescript he electronics steel plate and needs the car handled best between 1541 and 1555 grams.
#6103
I got a set of Schumacher cut staggers low profile front tires and noticed the bead was a real tight fit on JConcepts narrow rims and was hard to glue.
Do the Schumacher tires fit better on the Schumacher rims? I have never used those rims are they as good as the JConcepts?
#6105
R/C Tech Elite Member
