    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 04-29-2016, 09:45 AM   #46
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Wildcat1971 View Post
Wrong.....sell your car for maybe $125. But the b6 from tower for 309.99- coupon code. Boom you have converted for less than the cost of the anders tranny.
Friend/buddy/guy at the track/random RCTech member says.."But but but...I paid $270 for my B5m lite and added another $250 in 'hop ups'. You're telling me my car is now worth almost nothing??"
Me..."Yes my friend, that is exactly what I'm telling you. Welcome to the world of R/C Racing."
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 04-29-2016, 09:50 AM   #47
Suspended
Trader Rating: 61 (100%+)
I just helped a buddy of mine and his roommate indirectly setup their B5M lites not even two weeks ago. I kept it simple on mods since the cars came with schelle hop ups, but damn!
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-29-2016, 09:55 AM   #48
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Will my B5m tires and wheels fit the B6? What bout the B6D?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-29-2016, 09:55 AM   #49
B5 is old wont sell well at all now just the way it works, all the fancy hop ups aren't worth near the cost even when they are on a current generation car.
jslider is offline   Reply With Quote
Old 04-29-2016, 09:58 AM   #50
onefast8's Avatar
Trader Rating: 41 (100%+)
Hmm, no gear cover on b6!
Jake R.
onefast8 is offline   Reply With Quote
Old 04-29-2016, 09:58 AM   #51
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Yes
They are still good cars and will sell....for less money than 2 weeks ago though.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-29-2016, 09:59 AM   #52
I've got over excited and pre-ordered here in the UK.
Looks great to me; love the bolt in chassis weights, lots of nice little details.
Both transmissions look like fitting same chassis; easy to switch over if running slippery conditions. Probably sell my B5m with gear diff, keep the original ball diff and buy the other transmission parts for B6D, then just need front tower and arms to have either option. Mega!
andrewcoley is offline   Reply With Quote
Old 04-29-2016, 10:00 AM   #53
Super Moderator
It comes with a body.
Old 04-29-2016, 10:02 AM   #54
Trader Rating: 17 (100%+)
Originally Posted by RCBuddha View Post
Any idea what those Front Tires are?...Rears too for that matter
Scott R is offline   Reply With Quote
Old 04-29-2016, 10:05 AM   #55
Super Moderator
racer1812's Avatar
It amazes me how you can so politely state the obvious. Such a gentleman you are.
Old 04-29-2016, 10:12 AM   #56
Yes
Very true, I will continue to run mine for a while, you know until they get the new kit quirks worked out
Old 04-29-2016, 10:13 AM   #57
abailey21's Avatar
Trader Rating: 36 (100%+)
Probably Schumacher stagger rib fronts and mini pin rears, it's the goto for carpet tires
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-29-2016, 10:22 AM   #58
New Jconcepts carpet turf tires
Rhett McNair is offline   Reply With Quote
Old 04-29-2016, 10:25 AM   #59
Suspended
I HIGHLY doubt for their cover car they'd use another chassis manufacturer tires.
Old 04-29-2016, 10:35 AM   #60
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
It appears the body will cover the exposed gears so there is no need for a gear cover.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
FLYINGBRIAN
