    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 02-02-2017, 07:02 PM   #5536
Trader Rating: 18 (100%+)
Originally Posted by bmag5000 View Post
Losi just released their 2wd Stadium Truck, Associated shouldn't be far off.
Probably going to be called T6D or something wouldn't surprise me.
I kinda need it to replace my aging T4.2....lol
What does this have to do with the b6 or b6d?
Chris Brown is offline   Reply With Quote
Old 02-02-2017, 07:52 PM   #5537
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Nothing. He seems to like to post random things...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 02-02-2017, 08:19 PM   #5538
Its just the truck version of the B6D?
Okay whatever lets talk about the B6 and B6D
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 02-02-2017, 09:27 PM   #5539
Trader Rating: 15 (100%+)
new exotek flite released.... look so nice!
radioctrlhead is offline   Reply With Quote
Old 02-03-2017, 03:39 AM   #5540
Azzkikin's Avatar
Originally Posted by gacbora View Post
Anybody using a different rear wing than the AE or J Concepts that is more durable? Somewhat of a newbie and I'm going through wings like a fat guy at Hooters.
I'm using this Team Durango 1.5mm HD Straight Wing, it's pretty damn tough. And being a rookie, it shall last you a while even with the rubber side up.
https://www.amainhobbies.com/team-du...480015/p487572
I used it when I had a Schumacher, their wings were really weak. And it has lasted me into the B6D. I haven't even cut out the stock wing yet.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 02-03-2017, 05:25 AM   #5541
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
The Losi wings are nice and come pre-cut.
RC*PHREAK is offline   Reply With Quote
Old 02-03-2017, 05:49 AM   #5542
71schaeffer's Avatar
Trader Rating: 8 (90%+)
Guys that have tried the rear sway bar: I was thinking about using it on super highbite clay tracks but ive noticed most pros dont use them even on such conditions for 2wd buggy. Why is that?
71schaeffer is offline   Reply With Quote
Old 02-03-2017, 06:13 AM   #5543
Orion_2kTC's Avatar
I ordered a set of Schelle Aluminum hubs and I'm thinking of getting some of the lightened bones as well. The question I have is should I get the 65 or 67 mm bones? Do I require anything additional besides what I already have stock on the buggy to make them work properly? I've seen a post where someone used a 6mm hub instead of the stock 5.
Orion_2kTC is offline   Reply With Quote
Old 02-03-2017, 07:13 AM   #5544
rvrslt1's Avatar
Trader Rating: 24 (100%+)
I have the Schelle hubs that were also used on the B5M and use the 65mm axles.
rvrslt1 is offline   Reply With Quote
Old 02-03-2017, 07:18 AM   #5545
Trader Rating: 21 (100%+)
In order to use the 67mm bones, you have to also have either the BMI inserts or mill out the bearing recess in the hubs to push the bearings out 1-1.5mm. If you don't have/do either of those, you will need to use the standard 65mm bone length.
joncmack is offline   Reply With Quote
Old 02-03-2017, 07:21 AM   #5546
Orion_2kTC's Avatar
Thank you. 65mm it is.
Old 02-03-2017, 07:33 AM   #5547
Jmuck69's Avatar
Schelle will have the modified axles available this month to accommodate the 67mm axles. No need to machine or get the BMI inserts.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-03-2017, 07:37 AM   #5548
jmcelroy42's Avatar
Seeing the pics from the Factory Team drivers at the Reedy race, It looks like AE has something they're working on as well.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 02-03-2017, 01:03 PM   #5549
Found a set of JConcepts B5m titanium turnbuckles in my spare parts bin. I see that the lengths are different by 4mm, anyone using these on their B6d?
Thanks!
FDDA15 is offline   Reply With Quote
Old 02-03-2017, 02:57 PM   #5550
Logi Maker's Avatar
Thanks!
I'm using my Lunsfords from my 5m with zero issues.
Kyle Predmore
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
Allen Drebi, davinco
