    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 02-02-2017, 01:49 PM   #5521
Johnn27's Avatar
Trader Rating: 69 (100%+)
Default Spur cover
Originally Posted by mellow View Post
Not the stock one, but Schelle, Jconcepts and I think a few others make covers for the laydown.
I purchased one of the Jconcepts / shapeways covers for the laydown trans and I really like it !
Johnn27 is offline   Reply With Quote
Old 02-02-2017, 01:53 PM   #5522
Silverstonev8's Avatar
Funny you say that. I actually just finished putting mine on.
I do agree it's a nice piece...
Silverstonev8 is offline   Reply With Quote
Old 02-02-2017, 02:53 PM   #5523
Trader Rating: 18 (100%+)
Originally Posted by Wildcat1971 View Post
Cav won the reedy race with AE springs...
Guy's are running all different kinds of springs. I recently got the g force spring scale and noticed all kinds of interesting things. What I found testing kyosho, ae, losi, and yokomo springs is the ae ones had the greatest difference between pairs of springs. So if I was going to run only ae springs, I would buy several pairs of the same rate springs and "match" them.
Chris Brown is online now   Reply With Quote
Old 02-02-2017, 03:08 PM   #5524
rgrg2's Avatar
Trader Rating: 40 (100%+)
Default Cover
Nice!
Associated B6D B6 MT4S Jconcepts Reedy Schurr Speed Hobbywing Tekin
rgrg2 is offline   Reply With Quote
Old 02-02-2017, 04:14 PM   #5525
Phillip F's Avatar
Trader Rating: 15 (100%+)
LoL... He can use any spring and can still kick butt.... so as Rivkin and the other top pros.
Phillip F is offline   Reply With Quote
Old 02-02-2017, 04:31 PM   #5526
[QUOTE]Originally Posted by Silverstonev8
I do agree it's a nice piece.../QUOTE]
I agree!
gacbora is offline   Reply With Quote
Old 02-02-2017, 04:33 PM   #5527
Anybody using a different rear wing than the AE or J Concepts that is more durable? Somewhat of a newbie and I'm going through wings like a fat guy at Hooters.
Old 02-02-2017, 04:57 PM   #5528
LiL CeeZ's Avatar
I know this is blasphemy but I've been using the 6.5 precut losi wings. Those things last me forever and they're fairly thick. I just cut out the rear of the wing and pop 2 holes for the screws, takes a few seconds. They're pretty easy on your wallet too.
Pro line also has a double wing that you have to cut out. Its also high quality and lasts for a while. I'll get exact model names for you tomorrow if you need them when I go to throw down some laps.
Actually here's a link:
https://www.amainhobbies.com/team-lo...PfcaAtwN8P8HAQ
www.amainhobbies.com/proline-champion-1-10-buggy-wing-6.5-wide-2-pro6287-00/p487890
You can also try the pro line trifecta. I personally like these other 2 much better though.
Team Associated B6D
LiL CeeZ is offline   Reply With Quote
Old 02-02-2017, 05:11 PM   #5529
I run a proline trifecta and I put a thin layer of shoo goo on the top and bottom of the wing over the mounting points to reinforce it a bit more in the area where it is most likely to fail and haven't had an issue on my 4WD or 2WD thus far.
B64D | B6 | T5M | EB48.4 | Talion | EMB-TGH | Sakura Advance
daedalus is offline   Reply With Quote
Old 02-02-2017, 05:12 PM   #5530
Trader Rating: 478 (100%+)
I posted the same thing last year in the B5 thread! I had green springs stiffer than whites! The Kyosho springs are always right on the money.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 02-02-2017, 05:12 PM   #5531
Phillip F's Avatar
I race with a Losi wing and an Xray XB2 body on my B6.... it works for me.
Old 02-02-2017, 05:27 PM   #5532
Trader Rating: 16 (100%+)
Since you are a rookie driver, I would suggest picking up one of the SWorks wings.
https://www.amainhobbies.com/sworkz-...800awh/p267311
They are made of plastic instead of lexan and will last a lot longer. They are heavier, but a new driver won't notice the extra weight up high like a more experienced driver will.
MX304 is offline   Reply With Quote
Old 02-02-2017, 05:34 PM   #5533
mellow's Avatar
Trader Rating: 17 (100%+)
I still have my Avid springs from my B4. I think next practice day I'll test those. Only tried the Yokomo and AE springs so far though. I have so many things I want to try, but sucks when the closest track is 1.5 hours away!
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 02-02-2017, 05:38 PM   #5534
Thanks! I was looking at those. Wasn't sure if they would fit the B6.
Old 02-02-2017, 06:11 PM   #5535
Losi just released their 2wd Stadium Truck, Associated shouldn't be far off.
Probably going to be called T6D or something wouldn't surprise me.
I kinda need it to replace my aging T4.2....lol
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 9 (3 members and 6 guests)
allmtrgsrd, egalsim, SevetS
