    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 01-30-2017, 07:45 PM   #5476
JsK
JsK's Avatar
Originally Posted by 71schaeffer View Post
Guys I have a quick question, putting a light sway bar on the rear end would help with traction rolling through a fast high speed sweeper? I am basically running the b6d kit setup minus 35wt front and grey spring. Shocks all the way out on the arms. 17.5 motor, the track has a lot of bite. I also am running 2mm under the rear ballstud instead of 3 stock. Just need some advice thanks
I would raise the rear hubs first before trying a bar. What insert are you running?
JsK is offline   Reply With Quote
Old 01-30-2017, 08:18 PM   #5477
71schaeffer's Avatar
Trader Rating: 8 (90%+)
Originally Posted by Eli View Post
Does it 2 wheel around the corner before traction rolling? In most cases a roll bar should help.
Yes thats what it does is bycicles before it dumps
71schaeffer is offline   Reply With Quote
Old 01-30-2017, 08:19 PM   #5478
Just the kit insert. When you mean raise the hub are you talking ballstud or the hub itself to a the bottom hole?
Old 01-30-2017, 08:46 PM   #5479
JsK
JsK's Avatar
The B6 is built with the +3 or highest rear hub insert not sure about the D. I would try that
or go out .5 on the C and D blocks before a rear bar.
Old 01-31-2017, 12:51 AM   #5480
how big of a difference was there from the B5m to the B6d ? I'm looking to get the SC5m and was wondering if I should wait for a new truck or if it's going to be that big of a difference.
Thanks, Cory
TLR 22T 2.0
Dirtraycer is online now   Reply With Quote
Old 01-31-2017, 01:39 AM   #5481
Trader Rating: 18 (100%+)
The more important question would be when the next generation of truck comes out. They haven't even hinted at updating the current platform. There's no right answer, just how much you want to drive short course vs. how long you want to wait and see.
The other answer referring to the difference between the b5m and b6. There's quite a big difference, but the average racer isn't seeing drastic changes in lap times. But individual results vary.
Chris Brown is offline   Reply With Quote
Old 01-31-2017, 05:13 AM   #5482
Will do man thanks!
Old 01-31-2017, 06:50 AM   #5483
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
alright today or tomorrow I am planning to get my B6 sorted for our next carpet race. I got in my yokomo yatabe springs that others recommended. When you go to these springs over say what the carpet standard is (purple fronts however), do you go up or down in oil weight at all?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-31-2017, 12:10 PM   #5484
kdub's Avatar
Originally Posted by fast-ho-cars View Post
so if i get the new schelle 67mm bones, i can use standard B6 axles but whose hubs? schelle make offset inserts for this new part? cause i'm not finding the BMI ones
We have a B6 rear axle set coming in 2nd or 3rd week Feb, it will fit with Schelle or Associated aluminum hubs and won't change the car width. For now, you can get BMI inserts to use kit axles, email jason@bmiracing.com, he takes orders via email.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 01-31-2017, 02:06 PM   #5485
Originally Posted by Rogntudju View Post
Sorry to insist, no one to take a ruler and measure ?
I don't think your question can be answered as total length varies depending on what eyelets you use, and what you set the stroke to.
Tobey457 is offline   Reply With Quote
Old 01-31-2017, 03:23 PM   #5486
jonski's Avatar
Trader Rating: 233 (99%+)
Here is mine with the new 67mm Schelle bones. I am running the B5 Associated aluminum hubs with the BMI inserts. I also changed the hexes to 6mm.
jonski is offline   Reply With Quote
Old 01-31-2017, 03:57 PM   #5487
So I was wanting to get the aluminum D mount, just thought I would ask because I personally haven't asked this before but if you change toe or anti-squat on one block do you have to replicate it on the other one as well?
Hobbytown USA Gladstone,MO / StickyKicks RC / Fantom Racing / Clints Creations
Old 01-31-2017, 04:17 PM   #5488
Thanks. I'm not after absolute measure. I'm looking to know the approximate length of the shocks at rest, fully elongated, the stroke setting will be a kind of margin error
Rogntudju is offline   Reply With Quote
Old 01-31-2017, 04:21 PM   #5489
Silverstonev8's Avatar
Mine are approximately 75mm front and 88mm rear
If I remember correctly I have 2mm spacers in the fronts. I started the build a while back but got sidetracked by a 1/5 scale project. I just finished it a couple days ago...
Silverstonev8 is offline   Reply With Quote
Old 01-31-2017, 04:27 PM   #5490
have a look at the manual and see if the combination of toe/antisquat is what you need. if it is then theres no point in getting the d block. the d block just allows settings outside of whats available on the stock d block.
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Dirtraycer
