    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree286Likes
Old 01-29-2017, 04:28 PM   #5461
Weasely's Avatar
Originally Posted by belewis01 View Post
I also run a B6 at Norcal, but with the Team Powers motors. FYI, I geared down 2 teeth for the last track ( triple in the middle ) and use the same gearing for the new track with the big double and still have plenty of top end on the straight. Running 69/28 which works out to a FDR of 6.41. You would be 72/29 for a FDR of 6.46.
Most people there are not running a slipper in 17.5, or totally lock out the slipper. Also, I always run a fan on the B6 - you are probably under weight anyways so why not have a $15 fan to protect your motor?
I tried that with the stock slipper completely tightened for a while. It felt unsettled and nervous toward over steering when beginning to accelerate mid corner. This seems to be nicer, but i'm still tightening it down more and more. Now that I think about it, it seems there's got to be a better solution to that problem than using a slipper, huh?
I still have a ton of experimenting to do, just need more time to do it
I do have a fan in there now. I just never really used one when I had the reedy in the B5m previously.
Weasely is offline   Reply With Quote
Old 01-29-2017, 05:25 PM   #5462
Trader Rating: 16 (100%+)
Question for those running 17.5 stock class on carpet / turf. Are you using a gear diff, or sticking with the ball diff to keep the rotating weight down?
MX304 is offline   Reply With Quote
Old 01-29-2017, 06:17 PM   #5463
Originally Posted by radioctrlhead View Post
dont think that waterfall brace does anything at all.... not sure how a bend like that can provide any bracing behavior at all.
Also, does anyone know when we can expect aluminum rear hubs incorporating the use of 67mm dog bones? i am very interested in trying this out.
Flex your chassis front to back with the brace on, then loosen the bolts 90 degrees and flex the chassis the same way. Big difference. Try the same with the side rails.
Also waiting on hubs...
Fet2 is offline   Reply With Quote
Old 01-29-2017, 06:37 PM   #5464
JsK
JsK's Avatar
Gear diff with only 2 spider gears.
JsK is offline   Reply With Quote
Old 01-29-2017, 06:38 PM   #5465
Finalist's Avatar
I love the b6 with no waterfall. The rear stays more planted on high speed turns. You can either say it pushes or it keeps the rear from snapping around and making me correct. It was like having tires that are broken in versus brand new.
Finalist is offline   Reply With Quote
Old 01-29-2017, 07:46 PM   #5466
tsair's Avatar
Gear diff is actually 1g lighter than the ball diff. Strange but true, I weighed them back to back.
tsair is offline   Reply With Quote
Old 01-29-2017, 10:00 PM   #5467
Originally Posted by Rogntudju View Post
Hello everyone,
I'd like to know overall length of front (23mm body) and rear (27.5mm body) B6 shocks, full elongated length from axle to axle.
If anyone have already measured them, it would be very helpfull
Thanks.
Sorry to insist, no one to take a ruler and measure ?
Rogntudju is offline   Reply With Quote
Old 01-30-2017, 02:39 AM   #5468
Did you leave both cross pins in, or take out the one that's not in use?
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 01-30-2017, 07:33 AM   #5469
Thanks, I should be good to go then. Been running mod with my B5M with the two gear setup in my diff. I'll just do the same on the B6.
Old 01-30-2017, 07:34 AM   #5470
One cross pin. I've been running my B5 on carpet with a mod motor like that for a while with zero reliability issues.
Old 01-30-2017, 07:47 AM   #5471
What weight diff oil are you using with just the 2 gears?
I'm currently using 4K with the 4 gears.
roysays is offline   Reply With Quote
Old 01-30-2017, 08:07 AM   #5472
tsair: Gear diff is actually 1g lighter than the ball diff. Strange but true, I weighed them back to back.
All gear diff oil does not weigh the same.
mhuse6969 is offline   Reply With Quote
Old 01-30-2017, 03:26 PM   #5473
Cheers
Old 01-30-2017, 03:35 PM   #5474
71schaeffer's Avatar
Trader Rating: 8 (90%+)
Guys I have a quick question, putting a light sway bar on the rear end would help with traction rolling through a fast high speed sweeper? I am basically running the b6d kit setup minus 35wt front and grey spring. Shocks all the way out on the arms. 17.5 motor, the track has a lot of bite. I also am running 2mm under the rear ballstud instead of 3 stock. Just need some advice thanks
Hobbytown USA Gladstone,MO / StickyKicks RC / Fantom Racing / Clints Creations
71schaeffer is offline   Reply With Quote
Old 01-30-2017, 07:02 PM   #5475
Eli
Eli's Avatar
Does it 2 wheel around the corner before traction rolling? In most cases a roll bar should help.
Eli Westrup - SDRC Raceway - B6D - SC5M - B64D ALL FOR SALE!
Eli is offline   Reply With Quote
