    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 01-24-2017, 08:45 PM   #5416
Trader Rating: 23 (100%+)
How do we achieve a +1mm front axle height in this kit? The kit setup says "0" while most other setups say +1. My B6D came with two inserts, 3mm on top of the C hub and 1mm on bottom. Am I missing something?
chevmaro is offline   Reply With Quote
Old 01-24-2017, 10:47 PM   #5417
5tone's Avatar
the kit comes with +3mm and 0mm inserts
you need this: https://www.teamassociated.com/parts..._hat_bushings/
5tone is offline   Reply With Quote
Old 01-25-2017, 07:17 AM   #5418
So ive decided to run either a shorty pack or brick pack in my B6D.
Its still staying as a latemodel thou, as that's why I bought it to run it in that dirt oval class.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 01-25-2017, 07:30 AM   #5419
The D comes with a 3 and a 0, you need to buy the extra ones like stated before to get the 1. So if you want a 1 on the bottom then there would be a 2 on the top.
The 0 is actually .5mm thick so its a little confusing. You basically have a total combination between the top and bottom of 3mm
roysays is offline   Reply With Quote
Old 01-25-2017, 11:04 AM   #5420
Guys I'm about to pull the trigger on a b6 lay down. What are the must have option parts, weights, springs etc.. we run on outdoor astro. Thanks
EliasRou is offline   Reply With Quote
Old 01-25-2017, 07:19 PM   #5421
fast-ho-cars's Avatar
saw this on a new 67mm CVA bone
http://liverc.com/news/new_products/...ne_set_for_B6/
anyone know what they mean by (alternate axles req'd) ?
do these use a different out drive axle?
fast-ho-cars is offline   Reply With Quote
Old 01-25-2017, 07:41 PM   #5422
Trader Rating: 18 (100%+)
Those are used by some people in conjunction with the bmi racing aluminum hub inserts. It moves the axle out and decreases the extreme angle of the cva's. There's some discussion about it on here. I liked it a lot with the 5mm hexes in the rear.
Chris Brown is offline   Reply With Quote
Old 01-25-2017, 08:00 PM   #5423
rgrg2's Avatar
Trader Rating: 40 (100%+)
Default Laydown
Where can I find the steps to install a laydown on a B6D? Is it just take out the stand up and put the laydown in? Any info helps.
Associated B6D B6 MT4S Jconcepts Reedy Schurr Speed Hobbywing Tekin
rgrg2 is offline   Reply With Quote
Old 01-25-2017, 08:22 PM   #5424
Trader Rating: 478 (100%+)
Originally Posted by tom73 View Post
A few quick questions for the group. I'm running a b6d at my "local" (2 hour drive) indoor track - high bite clay. The track is rather small but flows well. I have to be out that way for work later this week and plan on stopping by for a few hours of practice and to test some tuning options. The car is setup pretty close to stock set up with a laydown transmission with the shocks in the rear of the tower. I plan on testing the shocks in the front of the tower. The issues I am having is it wants to break loose around half throttle when turning but the higher speed turns it holds up pretty well. Also if I apply the brakes it comes around fast. Some ideas I plan on testing are:
Move rear shocks in front of tower
Continue to adjust esc brake strength (already set pretty low)
Add travel limiters in rear shocks hoping to give more control when using brakes
Install front wing for additional front bite - even though it is pretty good
Testing pivot positions within the C&D blocks - Currently set middle / middle on both blocks.
Overall I am pleased with the handling but just want to make it better. Having the ability to brake would help as well as being able to accelerate harder in a turn. Also what are the advantages to wider / narrow and higher / lower pivot points?
This is one of those things where nobody could really give you decent advice without knowing your exact set up, the condition of your car, and have some knowledge of the surface. Its not all the same. My recommendation is to find somebody at the track that has the same car and isn't having your issues and then check his/her car. I, myself, just had to take business trip out to San Diego. Since I was there I decided to cart along 3 of my RC cars so that I could run some laps at SDRC (sort of bucket list thing....SDRC is 200 miles away). My car [B6] wasn't feeling that great so I walked up to a local and did exactly as I suggested. I asked for advice. The local picked up my car made some observations and then tightened my diff for me! Turned out that my set up was nearly identical to his but a loose diff and lack of tire sauce was causing my rear end to come out from under me on hard acceleration. Anywho, the moral of the story is "ask a local". Dakota Phend was there railing some laps too but I didn't bother him.....true story! Happened yesterday.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 01-25-2017, 09:12 PM   #5425
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Pretty much..
Yes.
Download the B6 manual...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 01-25-2017, 09:14 PM   #5426
Just go grab the B6 .pdf manual off the TA site and you should be good to go.
B64D | B6 | T5M | EB48.4 | Talion | EMB-TGH | Sakura Advance
daedalus is offline   Reply With Quote
Old 01-25-2017, 10:19 PM   #5427
rgrg2's Avatar
Originally Posted by Logi Maker View Post
Pretty much..
Yes.
Thanks!
Old 01-25-2017, 10:56 PM   #5428
lbckevin's Avatar
Trader Rating: 89 (99%+)
I ran the new Schelle Racing 65mm lightweight dog bones tonight. I got them from Kurt and I am sure glad I ran them. I ran them with the stock b6 diff and stock axles. The 65 are for stock cars and the 67mm are for the BMI inserts. The car was locked in , in the rear and worked great for the main. That was the only change for OCRC tonight and I improved from a fast lap of 22.3 to a 21.8.
Definitely give them a try and see for yourself.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 01-26-2017, 03:42 AM   #5429
Guys are using different axles with the 67mm bone setup?
Sean B. is online now   Reply With Quote
Old 01-26-2017, 07:38 AM   #5430
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
how are they better than the AE 65mm bones? Besides a very slight weight change.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
hairy17
