    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 01-20-2017, 12:45 AM   #5341
Diavel's Avatar
Looking at the pictures of the reedy race it looks like the works guys are not using the AE aluminium hubs. Does anyone know where they're from?
Diavel is offline   Reply With Quote
Old 01-20-2017, 04:35 AM   #5342
jmcelroy42's Avatar
Looks like prototype AE aluminum hubs specific for the B6.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 01-20-2017, 06:16 AM   #5343
Trader Rating: 18 (100%+)
Originally Posted by Pinkz View Post
stubby shorty or super shorty is a 2S pack that is near same size as one of the 1S packs of a 2S saddle pack
http://www3.towerhobbies.com/cgi-bin...&I=LXGBXH&P=SM LRP LiPo 7.4V 2600 Spr Shrty
http://www.ebay.com/itm/like/2319698...&ul_noapp=true ARROWMAX Lipo 2800mAh 2S Super Shorty
https://hobbyking.com/en_us/turnigy-...-approved.html Turnigy nano-tech Ultimate 2600mah 2S2P 90C Hardcase Lipo Super Shorty Pack
some racers at my track make their 8 minute 17.5 mains with their 1/10th buggies with no issues on runtime
I run the new protek lihv lipos (3600mah thin) and have no issues with a 7 minute 17.5 race in my buggy or truck. And I only charge to 4.23 volts. I get about 3300 mah when discharged to 3.1 volts. I like running this setup as I have greater flexibility in weight distribution.
Chris Brown is offline   Reply With Quote
Old 01-20-2017, 06:32 AM   #5344
Trader Rating: 478 (100%+)
Originally Posted by aeRayls View Post
If your shocks are on the front put the 0 facing forward. Shocks on rear 0 facing the rear.
I forgot about that.....because of the laydown!
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 01-20-2017, 07:26 AM   #5345
Trader Rating: 309 (100%+)
Business model, called keeping you hooked. #keepreachinginyourpockets
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 01-20-2017, 07:41 AM   #5346
Azzkikin's Avatar
I run the LRP 2600 and am getting 10mins out of them. Only charging to 4.22
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 01-20-2017, 07:56 AM   #5347
Looking at joona's car from the reedy race, I noticed he's running the b5 hubs with the 0 facing the rear and his shocks on the front of the arm.
Old 01-20-2017, 09:46 AM   #5348
Chris, I think you're right and Adam just explained it backwards....or maybe the laydown is that much different. Either way, for the second time I forgot that the laydown gave you the ability to move the tower & shocks around. When somebody suggested that I move the shocks to the rear for the first time I forgot to move the tower.....sad but true and funny at the same time. I remember asking my friend "why isn't this looking right?". I'll figure it out. As long as I remember that there is a difference I'll be ok.
Old 01-20-2017, 09:55 AM   #5349
.....I can verify that a few setups on PetitRC show the shocks on the front with the "0" facing forward. Once again, had I thought my way through it I would have figured it out. I'm more hands on and it was freezing in the garage so I didn't want to go look. Just for the record it was literally freezing.
Old 01-20-2017, 11:33 AM   #5350
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
It really doesn't matter which way it faces....The way Adam explained it was for hole orientation on setup sheets. That's what we were told when they came out and people were using them on the B5/B5M.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-21-2017, 07:35 AM   #5351
BRSracing's Avatar
Trader Rating: 53 (100%+)
I am looking for charge leads to eliminate the balance boards on my charger. I am charging 2S Batteries. I want to balance charge but it would be nice to get rid of the balance boards and just plug direct in the charger.
BRSracing is offline   Reply With Quote
Old 01-21-2017, 07:38 AM   #5352
https://www.amainhobbies.com/protek-...k-5241/p138774
roysays is offline   Reply With Quote
Old 01-21-2017, 08:59 AM   #5353
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Even better ones if you have both 4 and 5 mm packs..
https://www.amainhobbies.com/tq-wire...qw2620/p451177
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 01-21-2017, 09:01 AM   #5354
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
if you run packs that have both 5mm and 4mm bullet options, these or something similar could be useful:
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 01-21-2017, 09:55 AM   #5355
slakr's Avatar
Trader Rating: 28 (100%+)
I have both of those charge leads. The TQ ones are very nice, but still need the board. The ProTek ones are good as well and no need for the board.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
asadrian, Bull_Dog
