    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 01-16-2017, 12:38 PM   #5251
Originally Posted by Cain View Post
Amain was pleasant to deal with and matched towers member coupons.
How did you get amain to match tower coupons?
Tmack is offline   Reply With Quote
Old 01-16-2017, 12:41 PM   #5252
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Originally Posted by roysays View Post
I put green Yatabe on the rear and red on the front, running a B6 on astroturf.
Seems a tad better, hard to tell a big difference. I had the springs that came with the kit on it before.
did you notice anything better bump handling wise?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-16-2017, 12:52 PM   #5253
There is not allot of bumps on the track I race at but it did seems smoother over the few we have, not as stiff.
I kept the oil the same, 37.5F & 30R
roysays is offline   Reply With Quote
Old 01-16-2017, 02:37 PM   #5254
Tech Legend
Cain's Avatar
full info here:
A MAIN HOBBIES WILL MATCH TOWER COUPONS!!!
Cool thanks. That could be what I am looking for. I may also give the whole 1.8 rear piston thing a look.
Old 01-16-2017, 03:41 PM   #5255
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
I realize the B5M & B6D are different cars but can anyone tell me why the B5m calls for limiters in frnt & rear shocks & the B6d only front??? CAn anyone dumb it down for me as to what the limiters really do, just limit travel or is there more to it?
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 01-16-2017, 04:47 PM   #5256
Rear shock bodies are shorter to save weight in the b6d.
twistedneck is offline   Reply With Quote
Old 01-16-2017, 07:10 PM   #5257
Ahhh.. Got Cha
Old 01-16-2017, 09:21 PM   #5258
Originally Posted by AE_Stig View Post
2x1.8 flat lands better for carpet racing
i thought 3x1.4 landed better on carpet?
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 01-16-2017, 10:17 PM   #5259
Trader Rating: 29 (100%+)
It's mainly limiting droop which does a number of things. It produces less chassis roll which is better for higher grip. It increases traction as well on higher grip surfaces but doesn't jump and land as well. The geometry of the car has a lot to do with how much droop is ideal and there are many options with this car because of the longer rear shock tower and shock body variations as well as gull wing and flat front arm options
Skeeter36 is offline   Reply With Quote
Old 01-16-2017, 10:49 PM   #5260
Originally Posted by bongoray View Post
Hey all,
I'm running an ecopower slingshot 17.5 motor in my B6D with a 31 pinion and 69 spur. Everyone at the track looked at me like I had 8 heads. I showed them the manual recommends this gearing. Saturday was the first time I ran this buggy. Am I insane or are others just out there? I should note they were all running different motors too (modified).
I'll be running it again tonight to check motor temps.
It all depends on the size of the track and you need to keep an eye on the temps. We run on a small high grip clay and I run about an 8 FDR.
fiendcbr is offline   Reply With Quote
Old 01-17-2017, 01:00 AM   #5261
aeRayls's Avatar
Originally Posted by killshot01 View Post
For anyone running losi 22 3.0 rear hubs/axle and dogbones, what camber link setting and ball stud spacing?
Middle on bulkhead 1mm and shortest link on alum hub with 4mm
aeRayls is offline   Reply With Quote
Old 01-17-2017, 07:37 AM   #5262
3x1.4 can be a good option for some conditions but on carpet usually there is much less weight in the back and a larger hole piston is needed so there is less pack.
AE_Stig is offline   Reply With Quote
Old 01-17-2017, 07:39 AM   #5263
A lot of people in my area have converted their B5m to a Sprint Car.
There might be one available for the B6D also. I'm stumped I don't know if I should build one of them or just buy a Custom Works outlaw 3. The Outlaw 3 kit is $440
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 01-17-2017, 07:49 AM   #5264
Tech Legend
Cain's Avatar
the pack I have right with the 1.7s leads me to think that is what is causing me some issues. Great car though and its nice to have a community and team drivers to bounce stuff off of and view setups.
Old 01-17-2017, 08:26 AM   #5265
Johnn27's Avatar
Trader Rating: 69 (100%+)
Default Sprint
I raced sprint cars on a banked oval clay track for 2 years. I had a dd Custom Works. I personally never cared for the conversions. It's just ahead start out of the box. Although I have no experience with the newer Associated B5/B6 platforms on ovals. Try to find a Used one.
Johnn27 is offline   Reply With Quote
