    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 01-11-2017, 09:35 PM   #5176
Originally Posted by moto44 View Post
Okay here's a loaded question. For all you guys that had b5m's did you notice a big difference when you went to the B6D? I am on the fence about upgrading. Thanks
i went from a highly specc'd tlr 22 2.0 that podium'd at our nationals to a box stock B6 on carpet......... the B6 was waaaaaaaaaaaay better to drive. my laptimes were about the same, but i could reel off lap after lap after lap after lap at top pace compared to the inconsistant 22.
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 01-11-2017, 11:11 PM   #5177
Originally Posted by Logi Maker View Post
Jconcepts all in one (milled) is super dialed looking but not sure if it will.be released or when if it does...
I asked about it in the JConcepts thread a few weeks back, no solid date yet, but maybe Feb/March
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 01-11-2017, 11:40 PM   #5178
Originally Posted by Cain View Post
someone mentioned a type of tape they use as a chassis protector at their track that others use as well. I picked up a roll and may try it when I get another vehicle in.
Question for you other carpet guys, or, maybe this is just a general question. Sitting down looking at the vehicles I have as well as a recent one I had, one thing I noticed is going from one brand to another, it seemed the setup that worked quite well used a much lighter spring package (this is from various caculations on spring rates for comparisons) than what I am seeing on my B6 for carpet setups.
I am curious in general when you guys go from one brand to another, but stay in the same general class, how often would you see big rate differences in what you would run? Reason I ask is that I am thinking of ordering some more springs to try or use the brand I have here as they should fit to try out a lighter spring setup than what I currently use.
I run yatabe greens rear and yatabe reds up front . Everything else is cavs setup for carpet on the ae website. I think on carpet you can run the same spring on a wider variety of track layouts . With the Yatabe springs I tqed and won 13.5 at my club tonight . I have more fun driving this buggy than my yz2 that i sold with over 100 races on it .
Treasure Valley RC Eagle, Idaho
rc10b6 xb4 22sct3.0 rc8b3e
carpetburner is offline   Reply With Quote
Old 01-12-2017, 06:32 AM   #5179
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Running the same as a base too:
https://www.teamassociated.com/pdf/c...ieri_EOS_4.pdf
These springs I take it?
https://www.amainhobbies.com/yokomo-...s-1050/p417642
https://www.amainhobbies.com/yokomo-...as-800/p417646
have you run this in comparison to the springs listed on the setup sheet and have any thoughts on the difference in feel?
Here the track I would call has a few more bumpy sections, I am wondering if that could be part of the prob so may try next rate AE down on springs, the setup my daughter was running.
Just need a practice day ...
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-12-2017, 07:31 AM   #5180
What's the benefit in running 2 gears in the diff?
2hundy is offline   Reply With Quote
Old 01-12-2017, 09:24 AM   #5181
Yes those are the ones . Cavs eos springs were a tenth slower on the hero lap . I could hit fast laps more consistantly with the yatabe springs as the buggy felt more like my touring car used to.
Old 01-12-2017, 09:37 AM   #5182
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Less drag
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 01-12-2017, 10:26 AM   #5183
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
I got my B6D kit, Question, The turnbuckles feel very light, they aren't Titanium are they?? I figured with all the hop ups the car has you never know. lol
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 01-12-2017, 10:27 AM   #5184
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Nickel coated steel.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-12-2017, 10:37 AM   #5185
Less drag
How is this different from running 4 gears and thinner oil?
if I were to try this, would I simply remove just the two gears or the shaft as well?
Old 01-12-2017, 10:41 AM   #5186
Jmuck69's Avatar
Also, another benefit is more diff oil capacity. More consistent over the length of the run.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-12-2017, 10:44 AM   #5187
Tech Legend
Cain's Avatar
cool thanks. I'll keep those in mind. Is there a chart you recommend that breakdowns how those springs stack up rating wise compared to AE ones for comparison purposes (I know won't be exact, just curious for generalizations)
Old 01-12-2017, 10:49 AM   #5188
Azzkikin's Avatar
If I were to run a gear diff and try this, I'd leave in both shafts. Each shaft prevents the other from rotating. And the metal shaft rotating on the plastic housing might cause wear and misalignment. Just a thought.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 01-12-2017, 11:22 AM   #5189
Petit has a buggy big bore spring chart. I think some are measured and some are rated by oem. It's been helpful to me, even though it's not perfect. from the chart and the ones I've run, I would guess the Rear Yatabe greens are like an AE yellow, but with more pack at full travel.
Eddie_E is offline   Reply With Quote
Old 01-12-2017, 11:31 AM   #5190
Anybody known a stubby shortie wourks in this car?
Sodakota is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
