    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree286Likes
Old 01-10-2017, 12:59 PM   #5161
rgrg2's Avatar
Trader Rating: 40 (100%+)
Default Chassis
Which chassis protector is preferred on the B6D chasssis, the light or the thick?
Associated B6D B6 MT4S Jconcepts Reedy Schurr Speed Hobbywing Tekin
rgrg2 is offline   Reply With Quote
Old 01-10-2017, 01:01 PM   #5162
Phillip F's Avatar
Trader Rating: 15 (100%+)
Thick.... last longer
Phillip F is offline   Reply With Quote
Old 01-10-2017, 01:16 PM   #5163
Andrew Selvaggi's Avatar
Hi everyone, thank you for the awesome response to my Aussie Builds blog. By request I've finally got around creating a FB page linked to the wordpress blog.
For tips and tricks on, building, setup or maintenance on you AE Off Road rides, feel free to hit me up. The first few articles focus solely around the B6d. As soon as the 64 is out it will be up there as well.
https://www.facebook.com/aussiebuilds/
freezeframe007 likes this.
Team Associated ~ JConcepts ~ Hobby Wing ~ Team Orion ~ nVision ~ Sav÷x ~ Upgrade RC
Andrew Selvaggi is offline   Reply With Quote
Old 01-10-2017, 01:18 PM   #5164
Everytime i try something other than JConcepts i'm dissapointed in the wear.
For 15 bucks you get 2 from JConcepts and i've never worn through one (I run indoor clay).
I've used AE Clear (pretty good, just have to custom cut), Protek, and Scheel and they lasted a handful of runs before they work down on the kickplates or rear of the chassis.
B64D | B6 | T5M | EB48.4 | Talion | EMB-TGH | Sakura Advance
daedalus is offline   Reply With Quote
Old 01-10-2017, 01:23 PM   #5165
jonski's Avatar
Trader Rating: 233 (99%+)
Anyone running the tall tower and 31mm shocks on indoor medium bite clay tracks? What did you notice when you changed over to it? Thanks
jonski is offline   Reply With Quote
Old 01-10-2017, 01:25 PM   #5166
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
someone mentioned a type of tape they use as a chassis protector at their track that others use as well. I picked up a roll and may try it when I get another vehicle in.
Question for you other carpet guys, or, maybe this is just a general question. Sitting down looking at the vehicles I have as well as a recent one I had, one thing I noticed is going from one brand to another, it seemed the setup that worked quite well used a much lighter spring package (this is from various caculations on spring rates for comparisons) than what I am seeing on my B6 for carpet setups.
I am curious in general when you guys go from one brand to another, but stay in the same general class, how often would you see big rate differences in what you would run? Reason I ask is that I am thinking of ordering some more springs to try or use the brand I have here as they should fit to try out a lighter spring setup than what I currently use.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-10-2017, 01:44 PM   #5167
I'm not sure if it's thick or thin but I use one that the LHS has with their shop logo on it. The owner says the amount of time I spend on my lid I'm his best advertising budget investment
BruceR. is offline   Reply With Quote
Old 01-10-2017, 03:47 PM   #5168
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
^^^ Hahaha...this website needs a "Like" button ^^^
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 01-11-2017, 06:15 AM   #5169
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
You can't really compare like this. It is different from one company to another because the piston to shock body fit is different, the entire suspension geometry is different. The leverage the shock package has on the suspension is different.
You can compare changes you make. How a car reacts to stiffer or lighter springs for example. However, car A using a white spring and trying to equate that to car D using the same spring rate doesn't work.
Jon Carlson is offline   Reply With Quote
Old 01-11-2017, 08:02 AM   #5170
That is the same reason I spend more on chassis protectors than painting the body the side the crowd see's needs to look good lol.
jslider is offline   Reply With Quote
Old 01-11-2017, 04:45 PM   #5171
denon's Avatar
Default Body Question
This is my first time painting and cutting out a body....so forgive my question...but before I do, do you have to drill the hole for the spur gear? Doesn't seem like it would fit otherwise. Any other tips? Thanks.
B6 | SC5M
denon is offline   Reply With Quote
Old 01-11-2017, 06:39 PM   #5172
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Paint and use a body reamer... no biggie.
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 01-11-2017, 07:39 PM   #5173
denon's Avatar
Thanks. So there has to be a hole for the top shaft/spur correct?
I have read some posts about rubbing of the spur gear. Is this a big problem? Adding the spur gear cover worth it (91712)?
B6 | SC5M
Old 01-11-2017, 07:40 PM   #5174
moto44's Avatar
Trader Rating: 9 (91%+)
Okay here's a loaded question. For all you guys that had b5m's did you notice a big difference when you went to the B6D? I am on the fence about upgrading. Thanks
Barnstormers Raceway
Critters
________________________
moto44 is offline   Reply With Quote
Old 01-11-2017, 09:34 PM   #5175
Logi Maker's Avatar
Your need a hole in the body to alow the slipper nut room... (hopefully there is a body that avoids this in the future... pretty odd looking.. looks like a Losi 4 wheeler.)
I don't really see an issue with no.spur cover but the jcon one bolts up to the stock laydown plate. Schelle makes one along with a laydown plate.
Jconcepts all in one (milled) is super dialed looking but not sure if it will.be released or when if it does... you could always run a 52T spur...
Kyle Predmore
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
05PSD
