    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 01-04-2017, 12:04 PM   #5101
BRSracing's Avatar
Trader Rating: 53 (100%+)
Has anyone run the 17.5 trinity Monster Horsepower motor yet? I got the 7.5 and it is awesome. Was thinking of the 17.5 for my stock car. Not looking to derail the thread on a stock motor debate just looking for feedback on this motor from other b6 owners.
BRSracing is offline   Reply With Quote
Old 01-04-2017, 12:27 PM   #5102
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
I have one in my b5m & it flies, just the standard version not certified
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 01-04-2017, 01:13 PM   #5103
Im trying to setup my B6d for an outdoor race. would these all work together for front wheels? if not what setup would you guys suggest? im not partial to any tire or wheel brand. just dont want to order the wrong stuff.
http://www3.towerhobbies.com/cgi-bin...?&I=LXDHJY&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXBZEJ&P=7
http://www3.towerhobbies.com/cgi-bin...&I=LXFEXF&P=7#
caffeine357 is offline   Reply With Quote
Old 01-04-2017, 02:15 PM   #5104
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I would contact someone at the track to find out what the tires of choice are.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 01-04-2017, 02:46 PM   #5105
Andrew Selvaggi's Avatar
Default Aussie Builds - Maintenance Edition B6
Morning/Afternoon/Evening all, by request from racers I have created a new maintenance edition of the B6 Aussie Builds Blog. In this we go through some tips and step by step instructions on key rebuild items to keep your car performing at its best between races and in between race meets.
https://aussiebuilds.wordpress.com/2...-health-check/
As always feel free to hit me up with any questions or comments.
Team Associated ~ JConcepts ~ Hobby Wing ~ Team Orion ~ nVision ~ Sav÷x ~ Upgrade RC
Andrew Selvaggi is offline   Reply With Quote
Old 01-04-2017, 03:41 PM   #5106
More great tips from the Aussie Build Blog. thanks for taking the time to create this blog Andrew. Good Stuff!
hsp-sandiego is offline   Reply With Quote
Old 01-04-2017, 04:09 PM   #5107
Good stuff.
Bomba is offline   Reply With Quote
Old 01-04-2017, 04:23 PM   #5108
stegger's Avatar
Originally Posted by aeRayls View Post
Also forgot to mention that we also switch to the AE 5mm or 6mm rear hexes.
Not sure if anybody has noticed but the rear axles on the B64D have 65mm axles ! I wonder with the B64d rear hubs if this would give the same effect plus it would get rid of TRASH PARTS!!!
stegger is offline   Reply With Quote
Old 01-04-2017, 04:34 PM   #5109
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
I doubt they would work. The width of the diffs are not the same.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-04-2017, 04:45 PM   #5110
cementsurfer86's Avatar
Originally Posted by Skeeter36 View Post
Did you get this figured out
Skeeter, I ordered a new case and idler gear, which should be here on Thursday. Hopefully that'll fix it. I tried massaging and dremeling the case in all sorts of places but couldn't get it to go away.
It only happens when you put the two halves together, and I narrowed it down to the rub coming from the top-shaft area.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is online now   Reply With Quote
Old 01-04-2017, 05:04 PM   #5111
tsair's Avatar
Looks good! Just a suggestion -- if you could add an RSS feed for it, that would make it easier for people to follow.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is online now   Reply With Quote
Old 01-04-2017, 05:25 PM   #5112
that is my tire choice cain. im just verifying if those tires and foams will fit on those wheels i linked.
Thanks!
Old 01-04-2017, 10:09 PM   #5113
Tech Legend
Cain's Avatar
Thanks!
gotcha. My impression is that the wheels and inserts will work together. As for the wheels, The description say 2.4 and I don't get the same impression for the tires and inserts as being the EVO ones which work on those type of wheels from what I recall.
You would probably want this or something similar:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBVMV&P=7
Old 01-04-2017, 11:32 PM   #5114
Trader Rating: 29 (100%+)
It's just strange because it's a molded part and they are really hard to screw up. It's a process designed to do thousands of identical pieces. I'm wondering if the top shaft itself is faulty. That would be more likely
Skeeter36 is offline   Reply With Quote
Old 01-05-2017, 07:21 AM   #5115
If the case doesn't work, that'll be the next step. The case should be in today, so we shall see.
Currently Active Users Viewing This Thread: 9 (2 members and 7 guests)
3n90t, hamustar
