    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree302Likes
Old 01-02-2017, 01:31 PM   #5086
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by FDDA15 View Post
Newbie question:
I am building a set of 31mm shocks and followed instructions per manual (middle of page 15 steps 1-10) and I am getting a stroke length measuring 18.5mm. What am I doing wrong? Thanks in advance!
You're using a front shock shaft.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-02-2017, 01:39 PM   #5087
I wish it were that easy. I purchased everything to have a 31mm shock setup to include:
Kashima 31mm shock bodies
27.5mm shock shafts
etc...
FDDA15 is offline   Reply With Quote
Old 01-02-2017, 01:44 PM   #5088
Super Moderator
27.5mm shock shafts
etc...
Measure the shock shaft. 27.5mm shafts measure 47.75mm from end to end. If that's not the case you have something stuck in the shock body.
Old 01-02-2017, 01:58 PM   #5089
Measured.. internal machined washers and x-rings are free and clear.
I fill the shocks, cycle the shock shaft, allow air bubbles to rise to top of shock body, and fill until the fluid makes a dome over the top of the shock body. Screw shock cap on, cycle shock shaft slowly up until oil bleeds out, screw in bleeder screw while shock shaft is compressed. Any suggestions or tips on bleeding shocks?
Thanks!
Old 01-02-2017, 03:30 PM   #5090
Does it not matter much that the B5 aluminum hubs move the axle towards the rear by quite a bit compared to the stock B6 hubs?
Sean B. is offline   Reply With Quote
Old 01-02-2017, 05:00 PM   #5091
Super Moderator
The hubs don't move the axle to the rear. The only downside to the current AE aluminum hubs is that you lose the up/down adjustment.
Old 01-02-2017, 05:28 PM   #5092
Are you sure? Cause that's why I switched back to the stock hubs. We put cars side by side and the stock hubs were farther forward. Now I have to check again!
Old 01-02-2017, 05:33 PM   #5093
Super Moderator
Unless you didn't shim them properly. They are a direct fit...you just lose the up/down adjustment. New schelle hubs allow the up/down adjustment.
Old 01-02-2017, 11:34 PM   #5094
Phillip F's Avatar
Trader Rating: 15 (100%+)
OK.. just assembled my B6D kit and it's ready. When I first got my B6, the first thing that I demolished was the front bulkhead. I wonder if AE beefed up the front bulkheads or should I get the aluminum one?
Phillip F is offline   Reply With Quote
Old 01-03-2017, 12:28 AM   #5095
Trader Rating: 29 (100%+)
I'm assuming you ment b5m and the aluminum bulkhead we run but not because of durability, we use it for weight.
Skeeter36 is offline   Reply With Quote
Old 01-03-2017, 07:36 AM   #5096
I broke 3 then switched to the associated aluminum version and have not had a problem since.
frdtrkguy is offline   Reply With Quote
Old 01-03-2017, 07:46 AM   #5097
cementsurfer86's Avatar
Originally Posted by remix View Post
I'm thinking a New transmission case is required at this point. I'll pick one up Tuesday.. ugh I just wanted to get this car built!!!
Thanks for the help!
Let me know what you find, as I'm having the same exact issue.
I tried the gears in the stock standup case, and there's a hint of a rub, but not nearly as bad as the laydown case.
At this point I'm leaning towards a new case.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 01-03-2017, 08:52 AM   #5098
Thumbs up
Get the aluminum bulkhead. The plastic bulkhead is the only thing i have broken on my car. The aluminum part also tightens up slop in the front arms.
hsp-sandiego is offline   Reply With Quote
Old 01-04-2017, 08:50 AM   #5099
Did you get this figured out
Old 01-04-2017, 10:51 AM   #5100
BRSracing's Avatar
Trader Rating: 53 (100%+)
Originally Posted by brian mills View Post
AE aluminum hubs or shelle only?
Schelle, you can still adjust the axle height and if the ball stud breaks its a easy fix on the schell.
BRSracing is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
Mi4cxl, Raulote, tenex
