    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 12-29-2016, 03:50 PM   #4996
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
Originally Posted by Phillip F View Post
hey would appreciate it if you find a place where to get cheaper assorted size screws for the B6/D? Just to have a bunch in the tool box.
Ebay.. just type in b6 screw kit, don't be afraid of the hong kong sellers, Ive order like 5 times from them for the price you cant beat it takes about 3 weeks to get but, I got b5m titanium screws for 35 & full set of ball stud for 27, will get my b6 screws through them probably as well
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 12-29-2016, 04:05 PM   #4997
anyone know if the b6 ball studs are the same width as the b5 (interchangeable) ???
Old 12-29-2016, 04:33 PM   #4998
Trader Rating: 29 (100%+)
Im pretty sure they are the same. I held them up next to each other and they look indentical. I did not pull out the calipers though
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-29-2016, 05:06 PM   #4999
duckhead's Avatar
Yes, they are both 5.5mm balls and interchangeable.
duckhead is offline   Reply With Quote
Old 12-29-2016, 05:10 PM   #5000
denon's Avatar
Anyone run into the problem where the outdrive pin just does not fit? Both pins can fit into the other outdrive so it is not a problem with the pins....but the other outdrive will not fit....
B6 | SC5M
denon is offline   Reply With Quote
Old 12-29-2016, 05:19 PM   #5001
duckhead's Avatar
Originally Posted by Azzkikin View Post
7MM stock. Mine came with aluminum ones (AE# 91610).
SWEET< thanks i Didn't know, my car is in the mail, my T5M came with plastic so I assumed the same..
If you are looking for a tuning option in addition to the stock 7mm hubs, pick up a set of 6mm hubs (part #ASC71034) as well.
A lot of recent setup sheets posted are showing folks moving to the 6mm hubs.
I ordered a set, anxious to see what kind of difference they make.
Old 12-29-2016, 06:21 PM   #5002
Trader Rating: 25 (100%+)
My local hardware store sells M3 screws in black and stainless steel for less than a quarter a piece. All lengths.
jonnymorrow is offline   Reply With Quote
Old 12-29-2016, 07:12 PM   #5003
Trader Rating: 483 (100%+)
I'm due to make another purchase myself its been a couple years: https://www.mcmaster.com
A $200 order of stainless screws a few years ago probably was good enough to assemble a couple of dozen cars.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 12-29-2016, 07:27 PM   #5004
Trader Rating: 18 (100%+)
If you have a Mcfaddendale near you they have just about every screw size.
Chris Brown is offline   Reply With Quote
Old 12-29-2016, 09:08 PM   #5005
Rubiconmike's Avatar
Ya that happened during my build. I just worked threw it and caired on.
Rubiconmike is offline   Reply With Quote
Old 12-29-2016, 10:54 PM   #5006
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Can not beat the price of these guys. I hooked my scalers and the quality is spot on....
Literally like $.02 per stainless screw...
https://www.trimcraftaviationrc.com/...arch&search=M3
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 12-29-2016, 11:37 PM   #5007
Phillip F's Avatar
Trader Rating: 15 (100%+)
wow.... this is an amazing site. I'm only spending $60 and I have 100 pcs of each size of fhs and bhs for the b6.
Phillip F is offline   Reply With Quote
Old 12-30-2016, 03:45 AM   #5008
Thanks Everyone for your info, just curious, anyone know what their car weighs out of the box, just wondering how close to weight it is stock
Old 12-30-2016, 05:05 AM   #5009
Azzkikin's Avatar
Box stock with a 4000mah SMC battery = 1528g
with a 2600mah LRP battery = 1460g
That's with tires and painted body also.
I just realized that I changed the battery brace with the 2600mah battery, so that weight is probably wrong. The 4000mah battery was using the stock body and wing.
Dangit, I am also not running the stock body or wing with the light battery. Ok, it's official, I bring nothing to the table.
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 12-30-2016, 07:06 AM   #5010
WoW, so its right there close to the 1499 Roar legal weight.. Nice
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
