    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 12-27-2016, 09:45 AM   #4951
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by B44 View Post
I think it maybe this #91605 cva axle shims
If you remove those and still plan on using the mip diff there is going to be an incredible amount of left to right movement in the diff. You would need to revert back to the stock diff/bones.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-27-2016, 10:06 AM   #4952
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
but if the bone is hitting the t-nut, removing those shims probably shifts the whole diff over enough to keep that from happening (well, doesn't stop it from happening but when it does, the whole diff moves so there is no bind). obviously not the way you want to handle the problem though.
RC*PHREAK is offline   Reply With Quote
Old 12-27-2016, 10:15 AM   #4953
Super Moderator
Then you are going to shift the diff over when that nut hits the outdrive under power and I can bet the results aren't going to be good.
Old 12-27-2016, 10:26 AM   #4954
Azzkikin's Avatar
Anyone try the Imbue Brass pistons for the shocks?
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 12-27-2016, 10:30 AM   #4955
I'm wondering if he is running the cv shims out on the axles in the carriers and removed them, not the ones on the outdrives.
Tijuana_Taxi is offline   Reply With Quote
Old 12-27-2016, 10:47 AM   #4956
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by ridgerunner1 View Post
Our track is also high traction and i found that 7K in the gear diff is just right you may want to give that a try.
Tried 7K before on both my b6 and xb2 and considering its pretty cold in the track right now, the rear breaks loose coming out of ALL the corners , even just slightly giving gas exiting out a 90 or 180 degree. Reason I went to 4K....which helped a lot. I treed loosening the slipper but I would sacrifice snap to clear the jumps
francomang likes this.
Phillip F is offline   Reply With Quote
Old 12-27-2016, 11:12 AM   #4957
Trader Rating: 29 (100%+)
With the temps etc it may be wise to try a ball diff. I'll bet this looping out issue goes away or try to land right in the middle at say 5k diff fluid
Skeeter36 is offline   Reply With Quote
Old 12-27-2016, 11:14 AM   #4958
Reason I say that is in my experience you need a serious amount of grip for a gear diff to work in a 2 wheel buggy.
Old 12-27-2016, 12:37 PM   #4959
This is what I did wrong wording sorry.
MikeGassRacing is offline   Reply With Quote
Old 12-27-2016, 04:18 PM   #4960
Trader Rating: 14 (100%+)
So I have a nice broken in diff for a big race coming up but I want to turn tons of practice laps. I have a brand new gear diff I was wanting to run to learn the track. What gear diff oil should I use to be close to what a nice ball diff would feel like
Rcforlife13 is offline   Reply With Quote
Old 12-27-2016, 04:55 PM   #4961
GasGod's Avatar
anyone try alum shock towers? thoughts un these?
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 12-27-2016, 04:57 PM   #4962
Thrifty's Avatar
Tight or loose... thick or thin... try 5000.. or split it with the 3 to make ya some 4
You'll spend more time taking the diff out than you will changing the oil. I have some 3000, 5000 & 7000 from my 1/8th buggy I've been experimenting with. But I also have an extra gear diff to prep with different weight for a quicker change if need be..
Tekno 410.3 SL
RC10-B6D
RC10-B6
RC10-B64D
AuperD rwd drift.
Thrifty is offline   Reply With Quote
Old 12-27-2016, 05:05 PM   #4963
Would using shock oil 100 weight or less be bad. Can u make a gear diff turn smooth
Old 12-27-2016, 05:07 PM   #4964
Hey love this thread and just getting back into things after being away for many years. I bought a B6 and went to the local track to see what the common specs and requirements were. The requirements are pretty relaxed and for stock some people are running 17.5t and some people are doing 13.5t. So my questions is: Would it be stupid to buy a 17.5t and 13.5t motor if I can get a deal? Initially I would like to take some time to get used to things again so I thought starting with the 17.5t would make sense...
gacbora is offline   Reply With Quote
Old 12-27-2016, 05:13 PM   #4965
Thrifty's Avatar
I'm not sure how shock oil weights stand against gear oil weights...
Tekno 410.3 SL
RC10-B6D
RC10-B6
RC10-B64D
AuperD rwd drift.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
