    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree311Likes
Old 12-22-2016, 05:29 AM   #4861
Trader Rating: 15 (100%+)
Default Exotek Lipo strap
Anyone else running a low profile Lipo and brass under it. Look how far I can put the brass plate Haven't ran it yet
Rcforlife13 is offline   Reply With Quote
Old 12-22-2016, 05:31 AM   #4862
Pic didn't load.
Old 12-22-2016, 06:22 AM   #4863
A lot of people at my home track are going to the Yokomo green rear springs. Are most people going to the yatabe arena version or is it the standard Yokomo version? Also, what's the difference?
MikeGassRacing is offline   Reply With Quote
Old 12-22-2016, 06:34 AM   #4864
Trader Rating: 17 (100%+)
I believe they're using the standard version. The Yatabe arena springs are stiffer, and shorter
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Scott R is offline   Reply With Quote
Old 12-22-2016, 07:31 AM   #4865
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Correct. Standard version, part number is A1200.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-22-2016, 07:59 AM   #4866
I just bought a used b6 that came with what I believe to be yokomo greens...is there a way to tell which version I have?
MrLean is offline   Reply With Quote
Old 12-22-2016, 08:01 AM   #4867
count the number of coils. If I remember correctly the "regular" ones have 13 coils. I can verify when I get home, I have both versions
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Old 12-22-2016, 08:03 AM   #4868
Are those the springs i'm seeing in alot of pics of B6s that are kind of a rusty brown or bronze color?
Tijuana_Taxi is offline   Reply With Quote
Old 12-22-2016, 08:26 AM   #4869
Quick question. Anyone running the associated chassis weights that go under the servo or esc ??
Old 12-22-2016, 09:10 AM   #4870
I'm running the VRP versions
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Old 12-22-2016, 09:11 AM   #4871
Yes that's them
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Old 12-22-2016, 10:12 AM   #4872
I'm currently running a b6 on med-high bite and want to try to flat front arms, do I need to swap the tower as well or will the gull wing tower work?
Support your local track!!
rpc07 is offline   Reply With Quote
Old 12-22-2016, 10:36 AM   #4873
jmcelroy42's Avatar
Yes you need to use the corresponding tower with the flat arms.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 12-22-2016, 03:04 PM   #4874
Thrifty's Avatar
Anyone else here ever had an issue with stripping their servo gear? I have an aluminum steering rack and horn. Went through two yesterday.. ever had an issue till now. Nothing binding or catching..
Thrifty is offline   Reply With Quote
Old 12-22-2016, 05:01 PM   #4875
Phillip F's Avatar
With all aluminum parts connected to your servo and you get hit. crash head on, land skewed...etc. Your servo will absorb all that force and obviously strip your servo gears. Reason i dont upgrade to those aluminum steering parts yet because I know I am not that good in avoiding those type of crashes and conditions.
Phillip F is online now   Reply With Quote
Currently Active Users Viewing This Thread: 7 (4 members and 3 guests)
Aaron P, Chris Reilly, mgers75, walter white
