    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 12-20-2016, 06:48 AM   #4846
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default Does a Spektrum S6240 fit in a B6D
Yes that is what I am running in my car.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 12-20-2016, 07:58 AM   #4847
Trader Rating: 23 (100%+)
Thank you for the reply!!
sstretch is offline   Reply With Quote
Old 12-20-2016, 02:11 PM   #4848
Did you use the spacers on the servo mounts? I'm having a hard time getting the wires to "fold" between the servo and mount.
MrLean is offline   Reply With Quote
Old 12-20-2016, 02:44 PM   #4849
Jmuck69's Avatar
Cut away the rubber grommet except the part that pinches in the case. This would allow you to fold the wires.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-20-2016, 09:52 PM   #4850
Trader Rating: 14 (100%+)
Quick dumb question. I installed my diff with the screw on the opposite side of the spur gear. Does it really matter ? Just wondering if I gotta take it all apart again
Rcforlife13 is offline   Reply With Quote
Old 12-20-2016, 09:58 PM   #4851
Trader Rating: 29 (100%+)
Um I have ran it backwards on cars in the past and never had any issues but it would be wisest to pull it apart and flip it around. For safety's sake
Skeeter36 is offline   Reply With Quote
Old 12-21-2016, 06:19 AM   #4852
I'm running a vented slipper clutch. I have it tightened all most all the way down running 7.5 mod. Feel like the nut bolt shouldn't have to be turned in so much. Should I switch to those 3 pad systems ?
Old 12-21-2016, 06:38 AM   #4853
Trader Rating: 16 (100%+)
are your pads glazed up? I run 7.5 and use the stock slipper and the nut is flush with the end of the shaft
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Scott R is offline   Reply With Quote
Old 12-21-2016, 06:46 AM   #4854
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
I've noticed that it seems some slipper springs are a bit stiffer than others. I had one that you had to tighten down quite a bit t get the slipper set. I built another kit, that spring you didnt have to tighten down more than flush with the end of the top shaft (all in mod, 7.5). I think there are some out there in kits that are just a bit softer than others.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 12-21-2016, 07:02 AM   #4855
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
check pads as others have suggested. I would think going to a different pad setup whether it be something like the RC Shox / Mckune style pads or the avid / schelle style setup. I am using the RC Shox pads on carpet currently and really like them. Mckunes I use as well just on different brand of vehicles.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-21-2016, 07:02 AM   #4856
Azzkikin's Avatar
No one has tried to run the LRP Super Shorty in this car?
Team Associated - Axial - Reedy - LRP - SMC - Hobbywing - JConcepts - Proline
Azzkikin is offline   Reply With Quote
Old 12-21-2016, 08:00 AM   #4857
mxnickj's Avatar
Trader Rating: 51 (100%+)
Who has tried running without the waterfall and the battery all the way back? Benefits/Drawbacks?
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
Old 12-21-2016, 08:36 AM   #4858
I'm running my B6D in 2017 as a Oval Latemodel Car. In 2018 ill convert it back to offroad if offroad is back again, which as it stands yeah we should have offroad.
As an oval converted latemodel I can safely say its competitive against the Custom Works Rockets cars the way I have it setup. I'm getting beat by better drivers and faster motors.
I'm only running a 4600kv sensorless castle everyone else is running sensored 10.5 motors boosted which means they are over powering my car because boosted 10.5 is a 7.5.
On the lap time sheets they only beat me by 2 laps, which isn't half bad considering I'm running a car not suitable for oval racing but I managed to pull it off.
One of my first modification was putting NITRO FUEL tubing in my shocks to lower the car. Custom fitted SC10 body mounts that I got to fit by dremeling some of the plastic off.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 12-21-2016, 08:36 AM   #4859
sduffy77's Avatar
Trader Rating: 17 (100%+)
Hey Nick,
I just picked up the schelle battery hold down with the turnbuckle to eliminate the waterfall.
The intended benefit is so you can move the battery back for more traction. I'll probably have it up at Bumps & Jumps next week sometime for practice.
http://www.schelleracing.com/Schelle...-Strap-SCH1282
http://www.schelleracing.com/Schelle...le-Set-SCH1278
Team Associated SC5M | Team Associated T5M | Team Associated RC8b2e
Bumps & Jumps | Pit Stop Hobbies | Backhills RC
Pro-Line Racing | Maclan Racing | Xpert RC USA | Boca Bearings | Gens Ace | Mattox Designs | Race Ready Products | Sticky Kicks
sduffy77 is offline   Reply With Quote
Old 12-21-2016, 12:53 PM   #4860
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
http://www.rctech.net/forum/oval-larger-scales-more-5/
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Sal Amato
