    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 12-16-2016, 05:40 PM   #4801
gmintimidator's Avatar
Originally Posted by Phillip F View Post
Is it cheaper to just buy a B6D as oppose to buying a bunch of parts for a B6 to make it a B6D?
I've just purchased a B6D and looking at what I need to make it the carpet version to run indoors. AE now sells a conversion kit to make the transmission laydow, so that saves a couple of bucks. The best I can tell, you need the gear diff, new front tower and the front arms to make a B6D a B6
91705 Laydown Transmission conversion ($27)
91703 Gear Diff ($38)
91673 Gullwing Front Arms ($8)
91663 Wide Front Tower ($17)
gmintimidator is offline   Reply With Quote
Old 12-16-2016, 05:47 PM   #4802
Trader Rating: 35 (100%+)
On carpet u probably need the sway bar kit front and rear
CRaZeD is offline   Reply With Quote
Old 12-16-2016, 06:31 PM   #4803
asirolli's Avatar
Send a message via ICQ to asirolli
Default RC10B6 FT / CE ???
I'm waiting for a factory team kit or a special edition to move from b5m ce.
asirolli is offline   Reply With Quote
Old 12-16-2016, 10:49 PM   #4804
Phillip F's Avatar
Trader Rating: 15 (100%+)
I actually have the B6 .... so I have all that stuff... what I want to know is there a bunch of parts that I have to buy to make my B6 run on dirt track with low to medium traction.
Phillip F is offline   Reply With Quote
Old 12-16-2016, 10:53 PM   #4805
Phillip F's Avatar
BTW... for people running the Exotek Battery strap. You guys know where to get a longer turnbuckle to replace the one that came with the kit?
Old 12-16-2016, 11:09 PM   #4806
Hello Phillip F,
It looks like you have to twist the battery hold down plate by 180* to get the tunnbuckle mounted on the propper place!?
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 12-17-2016, 02:28 AM   #4807
Phillip F's Avatar
Originally Posted by micholix View Post
Hello Phillip F,
Yes. But the brace wont be resting on the center top surface of the battery.
Old 12-17-2016, 04:19 AM   #4808
Ok, i see what you mean, i just had a look at the exotek webpage and did see, they mounted it as i mentioned without the original waterfall brace!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 12-17-2016, 05:54 AM   #4809
There's not too much they could add to the kit really. It's pretty well appointed in 'team kit' form. So don't hold your breath.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 12-17-2016, 09:09 AM   #4810
Trader Rating: 18 (100%+)
Associated has gotten away from the special releases really. You're best bet ifor you're looking for a hopped up version is to look in the for sale section here.
Chris Brown is offline   Reply With Quote
Old 12-17-2016, 09:39 AM   #4811
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
Looking at there web page & the pics it appears they have the battery sides slid back closer to the motor as well & the brace the opposite direction, it doenst look like it made to have the battery that far forward
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 12-17-2016, 11:24 AM   #4812
Phillip F's Avatar
It actually tells you in their manual that you can get a longer turnbuckle if you need it ...BUT, when you go to the website, a longer turnbuckle does not exist. was just wondering how do I determine the size of this turnbuckle and plastic end so I can just buy it from another company.
Old 12-17-2016, 11:39 AM   #4813
Thrifty's Avatar
Measure it....
Thrifty is offline   Reply With Quote
Old 12-17-2016, 11:45 AM   #4814
I always see turnbuckles in mm lentgh,From the picture that looks way longer then ny turnbuckle ive ever seen, maybe just go buy threaded rod frm local hobby shop or home depot & make your own..
EDIT, found this with quick google search for 90mm turnbuckle
https://superstitionhobbies.com/prod...KW9hoCkaDw_wcB
ebay..
http://www.ebay.com/itm/Lunsford-5x9...oAAOSwa-dWp69N
Old 12-17-2016, 11:51 AM   #4815
Trader Rating: 19 (100%+)
any track with slicks you should run the laydown trans
Coke in a can is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (4 members and 2 guests)
Allen Drebi, EbbTide, pdario
