    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree286Likes
Old 05-13-2016, 06:13 PM   #466
RCBuddha's Avatar
Trader Rating: 33 (100%+)
http://www.redrc.net/2016/05/schelle...per-screw-set/
RCBuddha is offline   Reply With Quote
Old 05-13-2016, 07:53 PM   #467
Poppin Fresh's Avatar
Will the B5M body be compatible with the B6D?
"Nothin says luvin like fresh baked muffins, woohoo!"
Cruizin With R/C, RCBZ, Xray, Hudy, Novarossi USA, Futaba, Avid RC
Poppin Fresh is offline   Reply With Quote
Old 05-13-2016, 07:56 PM   #468
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Nope.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-14-2016, 01:15 AM   #469
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by RCBuddha View Post
Is it really worth $68 though??
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 05-14-2016, 01:31 AM   #470
Unless ur a serious racer:.. No lol u can get much bigger gains from more and mor B6 aftermarket parts thst are a better bang for the Buck
Slashn77 is offline   Reply With Quote
Old 05-14-2016, 06:40 AM   #471
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Going to venture to say.... for indoor clay.... B6D with laydown will be the norm. The car is just awesome to watch.. of course Spencer is driving it! He is going to have his hands full this weekend though... got some hot local talent.... track is coming in nicely and getting fast...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 05-14-2016, 06:41 AM   #472
Did his stuff ever make it there?
boucher is offline   Reply With Quote
Old 05-14-2016, 07:52 AM   #473
Trader Rating: 137 (100%+)
Originally Posted by Chris Brown View Post
What the guys who have lay down transmissions in other platforms are saying is the lay down transmission is allowing for greater corner speed. It's another tuning option.
It's true, when grip is up at LRH my YZ-2 CA can out corner every other traditional mid-motor car there.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-14-2016, 08:51 AM   #474
abailey21's Avatar
true, I'm not wasting my time with "stock", just gonna run mod to save money. $100 in parts goes WAY further
K.C.C.O.
Old 05-14-2016, 10:02 AM   #475
Titanium screws and ball studs are last on my list of upgrades (at least they were on my T5M). I may just run the B6 stock for a bit and get a feel for it before doing any upgrades. THis will be my first buggy EVER so I expect it will be a completely different animal.
BruceR. is offline   Reply With Quote
Old 05-14-2016, 10:04 AM   #476
abailey21's Avatar
It will be, but not as much as you think
K.C.C.O.
Old 05-14-2016, 10:06 AM   #477
I think the AE screw kit was only $55 or $58, and it included the bottom side screws too. I'll get that kit. Part of the fun for me is building the car and using the "go fast" (bling) parts. The tinkering and custom building is what I find the most fun in this sport.
Old 05-14-2016, 10:09 AM   #478
Johnn27's Avatar
Trader Rating: 69 (100%+)
Cool Letdown Tranny
I wouldn't be surprised if there is already a part number for the Laydown tranny conversion
Johnn27 is offline   Reply With Quote
Old 05-14-2016, 10:26 AM   #479
Here's your "conversion". It's just available parts that you can choose to build your car with.
91708 Laydown gearbox
91709 Chassis braces <----------- RCBuddha, add that to the list on the front page please.
91715 Laydown motor plate
91716 Idler gear
Old 05-14-2016, 01:31 PM   #480
RCBuddha's Avatar
91716 Idler gear
done
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
05PSD
