    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 12-14-2016, 10:50 AM   #4756
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by RC*PHREAK View Post
since when did tebo start driving like such a d!ck? A1 and A2 several "questionable" pass attempts. 4:05 of A2 he looked like he just totally meant to drive through rivkin.
Yet he will cry like a baby and tell the entire world if it happens to him.
suby723 is offline   Reply With Quote
Old 12-14-2016, 11:13 AM   #4757
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
well if you turn right in the middle of the straight one me. I'll lose patience with you as well. It's cool to block. But not in the middle of the straight turn randomly
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 12-14-2016, 11:14 AM   #4758
suby723's Avatar
That was just one situation but there where many times in a2 and a3 where tebo was trying to drive through Rivkin.
Old 12-14-2016, 11:14 AM   #4759
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
And we don't need to get into this.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-14-2016, 11:51 AM   #4760
^^^^what he said
We need to bag this with "which side the bolt of my diff. Should face "
Allen Drebi is offline   Reply With Quote
Old 12-14-2016, 12:17 PM   #4761
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Cain View Post
Question for you guys, I picked up a B6D for my daughter that came with some upgrades like the schelle slipper setup. How much of a performance difference are you guys seeing running this setup versus running say some garolite style pads (Mckune, RC Shox) on the stock setup (I am running this works great). Trying to keep things similar between us so not maintaining one thing special. The garolite pads work excellent, no issues there, but if there are things to the schelle setup that are work keeping around I am game since it came with a whole lot of spur gears.
I prefer the Triad style spurs and slipper. most consistent and the AE gears are often out of round. IMO the Triad style has better tolerances and wear. RCShox makes garo disks for that slipper.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-14-2016, 12:50 PM   #4762
Another fan of the Schelle Triad setup. running white inside/red/red stack. great for 17.5
hsp-sandiego is offline   Reply With Quote
Old 12-14-2016, 12:51 PM   #4763
suby723's Avatar
Originally Posted by Allen Drebi View Post
That depends on what side of the equator your on..
Old 12-14-2016, 01:13 PM   #4764
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
thanks for the info guys. I'll have to give this more a look then and go from there.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-14-2016, 02:12 PM   #4765
Good evening everyone,
Getting back into the game and just picked up a B6d. Would like to check in the the knowledgeable techs on here to get some advice. In the past I have ran castle, novak on my 1/10 4x4 SCT and latest Tekin on the 1/8 Truggy / Buggy. I have no restrictions in size motor being that I wont race it in a class (not a track close enough that races them) and no restrictions on price. I like to have what's best and don't throw out any hobby wings. Track is outdoor loose to packed dirt.
Thanks for everyones time
SuMMa is offline   Reply With Quote
Old 12-14-2016, 02:55 PM   #4766
Originally Posted by Chris Reilly View Post
You would need to look at the hinge pin angle to know. If it lessens the angle it is the opposite of what you said. Otherwise you are right.
It's raising up the C block making more of an angle so it's increasing the anti squat
roysays is offline   Reply With Quote
Old 12-15-2016, 05:56 AM   #4768
carbons2k's Avatar
Trader Rating: 21 (92%+)
Does anyone know what those inserts are that guys are running on the rear hubs? Theyre also using 67mm tlr rear axles.
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 12-15-2016, 06:05 AM   #4769
Jmuck69's Avatar
some are running BMI Racing rear hub inserts. Rivkin eluded to new rear aluminum hubs AE is working on that will have this feature built-in. moves axles out 1.5mm
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-15-2016, 08:23 AM   #4770
mxnickj's Avatar
Trader Rating: 51 (100%+)
Doesn't increasing anti-squat usually mean less grip though?
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
