    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 12-09-2016, 08:23 AM   #4681
I taped my battery using the stock laydown waterfall. looks like you can move the battery back quite a bit using a aftermaket battery strap with brace.
hsp-sandiego is offline   Reply With Quote
Old 12-09-2016, 10:50 AM   #4682
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
just to confirm again as it was posted but wanted to be sure before I ordered, I am got my kids a B6D here that I am setting up for them to run. The RPM B4 wide bumper fits right? I remember reading here but curious on that for sure. I figure alittle extra front protection could be a good thing, especially on carpet since it doesn't dig in.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-09-2016, 06:47 PM   #4683
Originally Posted by tsair View Post
Doesn't that take an SAE ballstud, 4-40 IIRC?
YES i had to tap the ballstud hole out to 3mm and i used a nut on the back just to be sure.
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 12-09-2016, 07:01 PM   #4684
Phillip F's Avatar
Trader Rating: 15 (100%+)
I've been racing with the batts forward and I like how it handles. I wonder with the Exotek batt strap if you can move the battery more forward than the stock battery strap.
Phillip F is offline   Reply With Quote
Old 12-09-2016, 07:30 PM   #4685
I actually just finished my build and am going to run some practice Sunday at sdrc. thats good to hear as i was worried rear traction might be a issue. Phillip - are you running your shocks in front or rear on the rear arms?
guessing you run at scvrc - have run there 3 a few times years ago / mom lives in Valencia. I remember that the couple who owns and operates keeps the clay super dialed and smooth.
Old 12-09-2016, 08:23 PM   #4686
Phillip F's Avatar
Scvrc has tons of traction especially right now. The cool weather retains all the moisture in the track. To sauce your tires would increase your chances of traction rolling on every corner. The track is now ran by a young crew and owner. Very helpful and knowledgable. To answer your question, i run my B6 just like the carpet setup. Rear shocks are mounted in front. I also do this with my XB2 to help it jump wing high.
Old 12-10-2016, 08:20 AM   #4687
Trader Rating: 89 (100%+)
can someone show how they mounted the VRP aluminum
battery brace with turnbuckle installed? I got no instructions, nothing with my order. I have it in the car , but in the all the way back position - closest to motor- it does not look right , all tweaked.
dan-o is offline   Reply With Quote
Old 12-10-2016, 09:26 AM   #4688
Trader Rating: 91 (100%+)
look at the exotek instructions, mounts exactly the same way
redracerd is offline   Reply With Quote
Old 12-10-2016, 11:15 AM   #4689
Thanks redracerd- I appreciate it!
VRP should include something for guidance.
Old 12-10-2016, 12:27 PM   #4690
There is no installation sheet? damn...so how do you know how to adjust for chassis stiffening?
FreeBandz is offline   Reply With Quote
Old 12-10-2016, 12:48 PM   #4691
I'm not sure if it will get the battery further forward but it does have a ton of adjustment to.
Support your local track!!
rpc07 is offline   Reply With Quote
Old 12-10-2016, 01:07 PM   #4692
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You don't adjust for chassis stiffening. It just a battery strap that eliminates the waterfall and uses a turnbuckle. Similar to the Schelle and others out there. It does allow some finer adjustment of where the pack goes but the turnbuckle is just there to brace instead of the waterfall...you adjust the turnbuckle based upon where the pack is mounted...it is not its own adjustment.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-10-2016, 01:11 PM   #4693
OHHHH! ok, I am pretty sure I read somewhere that the on the ones like the Exotek you could tune the chassis flex or something...
Old 12-10-2016, 01:20 PM   #4694
Super Moderator
No tuning chassis flex....but if you aren't careful you can create flex in the chassis
Old 12-10-2016, 02:25 PM   #4695
good point...my VRP turnbuckle battery brace came in the mail today...beautiful machining!!! great job VRP
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
abailey21, nanoverse
