    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 12-07-2016, 07:40 PM   #4666
Originally Posted by FreeBandz View Post
anyone running a mod motor with the box stock kit? if I wanted to run mod, what a good package of upgrades to handle the torque and abuse of mod racing?
im running a 10.5 in mine...only mods so far is tire weights on the chassis and the alloy D block....i have some sway bars to try....my only advice is to buy a spare for every part of the front end...lol
Lunchie is offline   Reply With Quote
Old 12-07-2016, 07:56 PM   #4667
Originally Posted by hsp-sandiego View Post
I am using the Losi servo arm with a Savox with no fitment or rubbing with perfect geometry and the kit setup. Sounds like issues when using the AE Aluminum servo arm.
im running a losi arm also and the geometry is perfect.
Old 12-08-2016, 12:58 PM   #4668
im running Savox with an Exotek aluminum servo horn, no 2mm ballscrew spacer, no servo spacers...I got clearance and issues to the right side only...
FreeBandz is offline   Reply With Quote
Old 12-08-2016, 01:55 PM   #4669
Eli
Eli's Avatar
I am running the black edition savox servo 1258tg black edition if that matters, no servo spacers, stock steering other than the exotek servo arm and I have no issues.
Eli Westrup - SDRC Raceway - B6D - SC5M - B64D ALL FOR SALE!
Eli is offline   Reply With Quote
Old 12-08-2016, 03:18 PM   #4670
Got my Exotek battery strap installed today. Got my order in last week while they were still in stock.
Support your local track!!
rpc07 is offline   Reply With Quote
Old 12-08-2016, 07:47 PM   #4671
BRSracing's Avatar
Trader Rating: 53 (100%+)
[QUOTE=rpc07;14761534]Got my Exotek battery strap installed today. Got my order in last week while they were still in stock.
Did you have to add foam to get it to work with the thin pack?
BRSracing is offline   Reply With Quote
Old 12-08-2016, 09:37 PM   #4672
I'm running the regular orange 1258tg...what could be my issue?
Old 12-08-2016, 09:38 PM   #4673
tsair's Avatar
Doesn't that take an SAE ballstud, 4-40 IIRC?
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 12-08-2016, 09:45 PM   #4674
Eli
Eli's Avatar
Post a pic. Maybe remove the 2mm spacer from the bell crank?
Old 12-08-2016, 10:42 PM   #4675
tsair's Avatar
If you're using no servo spacers, you have to use shorter screws.
Razor RC blog:
Old 12-09-2016, 02:02 AM   #4676
I used the same in my B5m setup, use a body reamer to enlarge the mounting hole in the Losi servo arm just enough to start the AE ballstud
FDDA15 is offline   Reply With Quote
Old 12-09-2016, 04:30 AM   #4677
OK I'm getting confused with the Yokomo Springs comparing them to AE. What color F&R would I need for a B6 on astroturf?
I'm currently running the kit springs which is orange on front & blue on the rear. What Yokomo's are about the same?
roysays is offline   Reply With Quote
Old 12-09-2016, 05:35 AM   #4678
jmcelroy42's Avatar
New Battery strap from Schelle
http://www.schelleracing.com/Schelle...-Strap-SCH1282
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 12-09-2016, 06:05 AM   #4679
Correct. I drilled and tapped one in a pinch.
mx836 is offline   Reply With Quote
Old 12-09-2016, 06:15 AM   #4680
[QUOTE=BRSracing;14761801]
Yes but not a lot. A thin foam pad under the battery strap itself is all you need.
