Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 12-05-2016, 12:48 PM
  #4636
BRSracing's Avatar
Trader Rating: 67 (100%+)
Originally Posted by "Smiley"
You can adjust the battery brace screws lower and it should work with the thin shorty's. I'll double check later today.
thanks, thinking about ordering will wait to see what you find out for sure.
BRSracing is offline
Old 12-05-2016, 01:27 PM
  #4637
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
my VRP stuff came in, very nice looking including the battery brace.
Cain is offline
Old 12-05-2016, 03:13 PM
  #4638
Finalist's Avatar
I'm going to try a set of hard arms.
I know of the positives harder parts, BUT do they break much more easily that stock arms?
Finalist is offline
Old 12-05-2016, 03:20 PM
  #4639
xyzracer's Avatar
Do the b5 ball cups snap right on or do i need new ball studs as well?
xyzracer is offline
Old 12-05-2016, 03:23 PM
  #4640
Same ball Studs as on the "5" series. Direct fit.
hsp-sandiego is offline
Old 12-05-2016, 03:29 PM
  #4641
Tech Legend
Cain's Avatar
took a closer look at my vrp stuff, looks like I am missing some parts from the CNC battery brace.
Came with the following:
- battery brace assembly
- turnbuckle
- turnbuckle ends with 1 "ball" insert on 1 end, none on the other
- 1 nut
Is it supposed to come with any screws, another ball insert that goes into the turnbuckle end, etc? If so, what are the sizes so I can get it together with what I have here?
Got a message and they sending out the missing parts. nice customer service. I have to say for being aluminum in comparison to the graphite, at least for towers, these feel pretty light.
Cain is offline
Old 12-05-2016, 03:40 PM
  #4642
Default Turnbuckles keep loosening
My toe-in turnbuckles on the front keep getting out of alignment within a lap or two. Usually it's just one side at a time that goes. Also, it's both sides that do it. It's not just a little bit either, it's something you can see from a distance. I thought about switching to the B5 ball cups and studs, but I'd like to not spend the money if I can avoid it. Anyone else experience this? For info purposes I run on indoor turf and am running the stock set up.
AllDamage is offline
Old 12-05-2016, 06:59 PM
  #4643
I run the thin shorties in mine. Just run the battery strap screws all the way done. It's a perfect fit.
Riverbluff is offline
Old 12-05-2016, 07:03 PM
  #4644
Just curious if anybody has run this on the black CRC carpet yet ? Looking for a rough setup and wondering what tires you were using.
Jason84 is offline
Old 12-05-2016, 07:23 PM
  #4645
Eli
Eli's Avatar
Trader Rating: 15 (100%+)
The ball studs are the same. I use the b5 ball cups and sometimes my camber and toe will get knocked out of alignment a bit so i don't think going to the b5 cups are going to solve anything just fyi.
Eli is offline
Old 12-05-2016, 07:46 PM
  #4646
Cain, when did you order? what state are you in? I ordered yesterday (Sunday)
FreeBandz is offline
Old 12-05-2016, 07:52 PM
  #4647
can you post some pics? I don't know if you already threw it on the car or not, but if you didn't, could you post some pics of the kit unattached as well as on?
Old 12-05-2016, 08:22 PM
  #4648
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
Couple update shots cause I'm finally home.
Should probably button up the wiring this week
abailey21 is offline
Old 12-05-2016, 08:51 PM
  #4649
Ok have had the b6 since first release and am totally loving it. But now I want more so looking to upgrade my motor. Going to put it to a vote here on the forum. Suurspeed or Fantom 17.5 with all the bells and whisltes on both which one should I get? Track is high bite carpet std to small size.
machfever is offline
Old 12-05-2016, 10:56 PM
  #4650
Trader Rating: 32 (100%+)
Schuurspeed is the fastest 17.5 stuff I have ran and I have pretty much ran everything currently available. Submit a form on his site and he will get you exactly what your looking for. By the way I am not sponsored or affiliated with Ron in any way, he just builds really good stuff
Skeeter36 is offline
