    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 12-04-2016, 04:53 PM   #4621
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Originally Posted by stuey View Post
Yeah defo the fasted that way across the bumps is keeping your wheels on the ground driving forward.
Thanks! I'll give that a look.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 12-04-2016, 06:17 PM   #4622
BRSracing's Avatar
Trader Rating: 53 (100%+)
Originally Posted by "Smiley" View Post
Vrp brace works with laydown and stand up transmissions.
does it work with a thin battery? Looks like it would be too high with the brace.
BRSracing is offline   Reply With Quote
Old 12-04-2016, 06:25 PM   #4623
How am I incorrect you said you are running purple and blue I'm assuming you are on roll bars I'm assuming you we're on the fast flowing track as per the EOS I assume you had the best part of 120 drivers running for two days practice bringin the grip up.
If all these are correct I stand corrected and apologise if not I fear your a little too stiff
But each to there own
If Suby is running at Extreme Raceway in Spring Hill, then 'bringing the grip up' isn't an issue since (as far as I know) they don't allow tire sauce on their carpet. Look up Extreme R/C Raceway on Facebook you can see the track layout and draw your own conclusions.
BruceR. is offline   Reply With Quote
Old 12-04-2016, 06:42 PM   #4624
suby723's Avatar
Trader Rating: 21 (100%+)
Yeah I do, my name is Aaron Kelly. I'm sure you have seen my cars and they are always dialed. It's ok though if somebody wants to insult me by offering advise.. no worries lol
freezeframe007 likes this.
suby723 is offline   Reply With Quote
Old 12-04-2016, 07:26 PM   #4625
Hey Aaron I missed the racing today. Work Next time they run I might stop by your pit and compare setups. So far my B6 is pretty good there and my driving is improving.
Old 12-04-2016, 07:52 PM   #4626
suby723's Avatar
Sounds good man please do. I couldn't race today either unfortunately. Life gets crazy around Christmas! Hopefully I'll be getting the b64 soon, can't wait to get that car going.
Old 12-05-2016, 05:37 AM   #4627
jmcelroy42's Avatar
Does anybody know how the offsets of the Schumacher wheels compare to the B5/B6 wheels? Looking at Cav's setup from the EOS race he is running the 6mm hex's, is that to correct for different offset wheels or because he is running a slightly wider pivot?
Also is this a pretty good starting setup for carpet? I have heard the Yatabe springs are better but I was just going to copy this setup to start with until I spend more money on stuff and know I like racing on carpet and start going there more. Thanks.
http://site.petitrc.com/setup/associ...gring20160429/
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 12-05-2016, 06:00 AM   #4628
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
You can adjust the battery brace screws lower and it should work with the thin shorty's. I'll double check later today.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 12-05-2016, 06:09 AM   #4629
"Smiley"'s Avatar
Originally Posted by FreeBandz View Post
If I keep the standup 3-gear, do I need to buy a longer turnbuckle? What is the size of the turnbuckle included in the kit? (I bought the one with it included)
The turnbuckle thats included is the same length as a kit B6 turnbuckle. The turnbuckle included should be long enough to work with the stand up transmission as well. I'll check on that later today as well.
Old 12-05-2016, 07:34 AM   #4630
are the Kashima coated shocks just for looks, or do they provide a performance advantage?
FreeBandz is offline   Reply With Quote
Old 12-05-2016, 08:36 AM   #4631
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
When paired with the machined shock pistons they feel smoother....I don't think it equates to faster laps however.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-05-2016, 10:31 AM   #4632
stuey's Avatar
Yeah I had a look track looks pretty cool didn't see any EOS carpet tho just ozi
I may be mistaken
stuey is offline   Reply With Quote
Old 12-05-2016, 10:34 AM   #4633
stuey's Avatar
I believe the shu wheels are about 1mm narrower offset
And yeah wider track narrow hex keeps track width the same it changes shock leaverages and roll centre the car will tend to be more stable when landing off jumps
Old 12-05-2016, 12:13 PM   #4634
CCristo's Avatar
Trader Rating: 55 (100%+)
Anyone have any insight when the new style rear hub and longer CVA bone is going to be available?
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 12-05-2016, 12:47 PM   #4635
Jmuck69's Avatar
I don't think anything is planned or info released. there is speculation from one image of a unique hub being tested on Cav's car but that is it. Don't know if it has a longer CVA bone or not.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
