    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree301Likes
Old 12-04-2016, 10:52 AM   #4606
raved007, do you have a pic of the whole car I could see?
FreeBandz is offline   Reply With Quote
Old 12-04-2016, 10:58 AM   #4607
Trader Rating: 32 (100%+)
Originally Posted by FreeBandz View Post
where did you get those braided battery wire covers? Those are BADASS!! does that Exotek battery brace work with the standup 3-gear or just the laydown?
The exotek battery brace works for stand up and laydown. Also braided wire bought in ebay 1/4 size
raved007 is offline   Reply With Quote
Old 12-04-2016, 11:07 AM   #4608
tsair's Avatar
Originally Posted by Cain View Post
yeah I got that part, what i am getting at is where are the standard towers actually better. So in short, is it a wash on surfaces that are smoother, smaller jumps, etc. Then as you go to what you described, the longer shocks are the ticket. So in short, if its a wash, they might as well just go long the whole time.
That's what I am wondering.
I haven't gone to B5 shocks, but the B6 shocks are lighter and lower CG.
tsair is offline   Reply With Quote
Old 12-04-2016, 11:13 AM   #4609
Tsair got yours payment but please PM your Shipping ADD.
Old 12-04-2016, 12:32 PM   #4610
B44
B44's Avatar
when using the 31mm rear bodies/ and taller tower do you use the same shafts.
B44 is offline   Reply With Quote
Old 12-04-2016, 12:37 PM   #4611
Exotek carbon fiber adjustable battery straps are out of stock and on backorder everywhere...I just copped the VRP aluminum battery strap w/ turnbuckle set up.
Old 12-04-2016, 01:03 PM   #4612
Silverstonev8's Avatar
Yes
Silverstonev8 is offline   Reply With Quote
Old 12-04-2016, 01:09 PM   #4613
stuey's Avatar
Originally Posted by suby723 View Post
Your incorrect. I was on purple front and blue rear same as Ryan's eos setup. I've ran this same shock setup on a yz2 xb2 and now the b6. It's $$ but to each there own.
How am I incorrect you said you are running purple and blue I'm assuming you are on roll bars I'm assuming you we're on the fast flowing track as per the EOS I assume you had the best part of 120 drivers running for two days practice bringin the grip up.
If all these are correct I stand corrected and apologise if not I fear your a little too stiff
But each to there own
stuey is offline   Reply With Quote
Old 12-04-2016, 01:21 PM   #4614
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
Originally Posted by stuey View Post
... I fear your a little too stiff ...
heh heh ...
More serious note, would you recommend going to say the next spring level softer if the surface is a bit more bumpy than what the setup was used on? thinking maybe next spring softer (already doing that on front) and say 50cst lighter.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-04-2016, 01:28 PM   #4615
Trader Rating: 15 (100%+)
Ok. I run on dirty and clay. Should I get the carpet and buy a ball diff or go dirt and get the laydown. What's working best from racers opinion
Rcforlife13 is offline   Reply With Quote
Old 12-04-2016, 01:33 PM   #4616
suby723's Avatar
Trader Rating: 21 (100%+)
Dirt and lay down is the best way to go.
suby723 is offline   Reply With Quote
Old 12-04-2016, 01:55 PM   #4617
stuey's Avatar
heh heh ...
Yeah defo the fasted that way across the bumps is keeping your wheels on the ground driving forward.
Old 12-04-2016, 02:04 PM   #4618
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Vrp brace works with laydown and stand up transmissions.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 12-04-2016, 02:24 PM   #4619
Trader Rating: 91 (100%+)
yes, they are on mine
redracerd is offline   Reply With Quote
Old 12-04-2016, 02:41 PM   #4620
If I keep the standup 3-gear, do I need to buy a longer turnbuckle? What is the size of the turnbuckle included in the kit? (I bought the one with it included)
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
bathsalts
