    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree311Likes
Old 11-28-2016, 10:49 PM   #4486
Eli
Eli's Avatar
Default Schelle +1
It appears that they are not in between the ae standard and +1 akerman plates but more like a +2 as it shifted the hole even further over towards the rack. I had suspected there was a difference when I took the aluminum ae +1 plates off to put the carbon Schelle +1 plates on because you know it's carbon and looks cool and after installing them I noticed my toe was toed in some. That was about a week ago and chatter in the pits had brought that up and today as I was prepping my car I removed them and compared all 3 sets I have (ae standard, ae +1 and Schelle +1) by sliding the screws through the holes to align them up on top of each other is when it became clear there was a difference. As I am typing this I realized I have some of the standard Schelle akerman arms but did not compare those but I imagine they're the same as the ae standard akerman but will look tomorrow.
I suppose these could add to the tuning options out there and in no way am I trying to say anything bad about them I imagine they have their advantages.
Eli is offline   Reply With Quote
Old 11-29-2016, 02:52 AM   #4487
5tone's Avatar
Thank's for your returns on the steering arms, it helps.
Do you try shiming the steering rack ?
Do you feel a difference with an extend steering arm ?
5tone is offline   Reply With Quote
Old 11-29-2016, 05:55 AM   #4488
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Originally Posted by man1ac View Post
If I get this right 91548 Alum. rear hubs from my sc5m should fit to my B6D, correct? (Worth switching?)
These the right ones for my B6D: ??
VRP B6 7075 CNC Rear Shock Tower (Black) - Option Tower 1
VRP B6 7075 CNC Front 'Option' Shock Tower (Black) - Flat Arms
Yes, those towers are what you need. Being the option towers, they eliminate the outside 3rd hole while adding a middle hole between the inside and middle original holes.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 11-29-2016, 07:20 AM   #4489
Eli
Eli's Avatar
I don't have enough time with running the car to tell a difference between the arms, I originally built the car with the ae +1 steering akerman and have only about 5-6 race days on the car.
I run 1mm behind the steering rack ball stud if that's what you're referring to.
Eli Westrup - SDRC Raceway
Old 11-29-2016, 08:32 AM   #4490
does anyone know if the composite steering arms will fit an aluminum steering block? Or do I need to purchase aluminum steering arms?
FreeBandz is offline   Reply With Quote
Old 11-29-2016, 08:58 AM   #4491
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
The steering parts are interchangeable..You can use any combination of Aluminum / Plastic together
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 11-29-2016, 09:14 AM   #4492
Thanks!
Anyone running mixed composite/aluminum steering setups? Advantages? or should I just look to go full aluminum once more parts come out? I was just worried that the plastic steering arms may develop slop...
Old 11-29-2016, 09:17 AM   #4493
Super Moderator
Thanks!
I initially built the car with all the aluminum steering goodies. Felt like the front end had too much weight so I went to the all plastic setup (along with a LP servo). I now am running the plastic arms with aluminum ackerman link
Old 11-29-2016, 09:24 AM   #4494
kdub's Avatar
I developed the type 1 steering arms separately from Associated, so the Schelle parts are not a duplicate of the Associated +1. The intent of both parts is the same, to give more Ackermann and help the front end corner faster.
Sorry if there is any confusion in the naming strategy, at the time we didn't know the AE parts were coming or what their name was. If I can get my hands on some AE +1 I will test them and let everyone know if there is much difference on the track.
The Schelle std B6 carbon steering arms are an exact duplicate of the kit parts. Hope this helps.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 11-29-2016, 09:24 AM   #4495
hmm, very interesting...so far my car is bone stock--I just ordered a Savox 1258TG servo and an Exotek Aluminum Servo Horn--don't know how heavy the front end will be with the full sized servo vs low pro, but I think I'll just wait until Schelle puts out some aluminum arms because I wanted the Schelle aluminum steering block as well...till then Ill just keep the car stock...
Old 11-29-2016, 09:26 AM   #4496
are aluminum arms out yet? I didn't see them on the website or on any online shops...
Old 11-29-2016, 09:33 AM   #4497
Super Moderator
The arms that Kurt is referring to are AE part numbers 91679 & 91680. They bolt to the steering block that is attached to the caster block.
Old 11-29-2016, 09:38 AM   #4498
Eli
Eli's Avatar
Thumbs up
Thanks for chiming in Kurt that makes complete sense. I think it worked out in a good way seeing how there are more options now for akerman settings.
Old 11-29-2016, 10:42 AM   #4499
my apologies I am a PURE newbie who is just really getting addicted to this...I meant the aluminum steering bellcranks! Is Schelle going to make aluminum bellcranks?
Also, would it be normal to just forgo the slipper and go directly to a lockout for 17.5 stock as a new racer? Is the lockout for stock racing essential?
Old 11-29-2016, 02:30 PM   #4500
Phillip F's Avatar
Trader Rating: 15 (100%+)
No. But if you have regular slipper and lockout selection, it would be a good tuning option. Especially if u race in a track that has inconsistent traction.
Phillip F is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
james101291
