    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 04-29-2016, 08:39 AM   #31
Suspended
Trader Rating: 61 (100%+)
Spencer already running all the added weights...
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-29-2016, 08:44 AM   #32
Nice lookin car, but I don't see me swapping this out for my B5M for the track that I run at.
APInes is offline   Reply With Quote
Old 04-29-2016, 09:10 AM   #33
Yanks213x's Avatar
What is the actual benefit of the lay down transmission? There are some obvious weight distribution changes.. does it help with corner speed.. etc?
Yanks213x is offline   Reply With Quote
Old 04-29-2016, 09:12 AM   #34
celt's Avatar
And the Alu steering rack!
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 04-29-2016, 09:19 AM   #35
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Team Associated B6 Intro at EOS
http://eos.redrc.net/2016/04/video-t...-introduction/
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-29-2016, 09:20 AM   #36
Suspended
more corner speed. More predictable under hard braking.
At the sacrifice of rear bite.
Old 04-29-2016, 09:24 AM   #37
Suspended
AE is very lucky to have Kody.
Old 04-29-2016, 09:32 AM   #38
Johnn27's Avatar
Trader Rating: 69 (100%+)
Thumbs up B5M to B6 or Laydown Conversion
Will Associated be offering a conversion to convert your B5m to a B6 or a lay down conversion or is this a totally different car, doesn't look that different?
Looks like the B6D is a good option for 17.5 racing !
Johnn27 is offline   Reply With Quote
Old 04-29-2016, 09:35 AM   #39
Suspended
I'm sure they will. Except it'll come in kit form. You buy the B6D or B6 kit, take off your b5m body, roll the b6d or b6 kit under your body, then put it on. Boom, converted.
Old 04-29-2016, 09:35 AM   #40
Super Moderator
Totally different....I could see a B6D to B6 conversion but nothing B5 related.
Old 04-29-2016, 09:36 AM   #41
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
A fast guy that is also an engineer?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-29-2016, 09:38 AM   #42
Wrong.....sell your car for maybe $125. But the b6 from tower for 309.99- coupon code. Boom you have converted for less than the cost of the anders tranny.
Old 04-29-2016, 09:38 AM   #43
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
This would be my GUESS
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 04-29-2016, 09:42 AM   #44
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
The B5M line of bodies do not work with the B6 line up
pink_sleeve is offline   Reply With Quote
Old 04-29-2016, 09:43 AM   #45
Suspended
Pft, with enough heat and cutting, I can make anything fit.
Currently Active Users Viewing This Thread: 5 (2 members and 3 guests)
88davidw, Triple A
