    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 11-15-2016, 08:58 PM   #4336
JsK
JsK's Avatar
Originally Posted by MrLean View Post
How far are you supposed to fill the gear diff with oil? Is it possible to over-fill it?
http://site.petitrc.com/setup/schuma...GearDiffBuild/
Yes this is a Schumacher diff but the concept is the same. Shim the outdrives
until there snug but don't bind in the diff halves, make sure to use plenty of
grease/green slime on the Oring and shim faces, And don't overfill.
Use the second side gear in the diff as a guide.
Overfilling the diff is the #1 reason they leak.
JsK is offline   Reply With Quote
Old 11-16-2016, 01:08 AM   #4337
what pistons to get for an otherwise stock setup b6 running high bite carpet?
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 11-16-2016, 01:41 PM   #4338
Default internal gear ratio
hey guys,
how do you determine the internal gear ratio ???? is it the same as b5m ??? what spur/pinion combo are racers using ? thanks.
fliedlice is offline   Reply With Quote
Old 11-16-2016, 03:59 PM   #4339
lbckevin's Avatar
Trader Rating: 89 (99%+)
same 2.60
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 11-16-2016, 06:18 PM   #4340
Trader Rating: 32 (100%+)
Does anyone running bulkhead brass in medium track how you compare with the stock one?
raved007 is offline   Reply With Quote
Old 11-16-2016, 08:10 PM   #4341
Thrifty's Avatar
Originally Posted by lbckevin View Post
same 2.60
Is that for stock or would that work for mod as well?
Thrifty is offline   Reply With Quote
Old 11-16-2016, 08:12 PM   #4342
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
2.6 is the internal ratio of the transmission...for gearing recommendations you can refer to the manual.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 11-16-2016, 08:43 PM   #4343
RCBuddha's Avatar
Trader Rating: 33 (100%+)
http://www.redrc.net/2016/11/rdrp-b6...ock-mount-set/
RCBuddha is offline   Reply With Quote
Old 11-16-2016, 09:22 PM   #4344
Pinkz's Avatar
those look like the exotech ones or vice versa
It rubs the lotion on its skin or else it gets the hose again.....Yes, it will, Precious, won't it? It will get the hose! https://www.youtube.com/watch?v=cyn0DVSn96I
Pinkz is offline   Reply With Quote
Old 11-17-2016, 12:57 AM   #4345
many of you will have seen this on facebook, but heres my B6 ready for carpet
RC10 B6
LC Racing truggy,
Old 11-17-2016, 06:31 AM   #4346
Mason's Avatar
gives you "wings". you need one more
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-17-2016, 07:08 AM   #4347
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
anyone got recent thoughts on using the sway bars? I need to play an order tonight so I don't lose some tower credits and I was thinking of buying just the rear kit for now and going from there. Or, for those who know people or are using them, are you using them both front and rear?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 11-17-2016, 07:55 AM   #4348
Who is that Guy's Avatar
I'm using them front and rear it keeps the car flatter in the corners and seems to make it a bit easier to drive. I have not ran with just the front or rear only.
QUOTE=Cain;14738408]anyone got recent thoughts on using the sway bars? I need to play an order tonight so I don't lose some tower credits and I was thinking of buying just the rear kit for now and going from there. Or, for those who know people or are using them, are you using them both front and rear?[/QUOTE]
Who is that Guy is offline   Reply With Quote
Old 11-17-2016, 10:04 AM   #4349
Tech Legend
Cain's Avatar
Thanks for the info. What conditions do you use them on and if you have a setup you care to post would love to see it.
Thanks!
Old 11-17-2016, 07:48 PM   #4350
RCBuddha's Avatar
http://www.redrc.net/2016/11/rdrp-b6...oulder-screws/
http://www.exotekracing.com/b6-22-se...black-edition/
http://www.exotekracing.com/b6-batte...-fiber-b6-b6d/
