    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 11-10-2016, 10:51 AM   #4291
team green's Avatar
Originally Posted by Wildcat1971 View Post
I just refuse to put aluminum towers on my car....
+1
team green is offline   Reply With Quote
Old 11-10-2016, 01:43 PM   #4292
RandyB's Avatar
Originally Posted by Pinkz View Post
anyone know which TLR aluminum dogbones will work on the B6D? i saw a post awhile back somewhere, can't find it
also saw a photo of a battery brace for B6D that where you remove waterfall and run a link from gearbox to top of battery plate. anyone know who makes it for sale? maybe just a one off custom?
67mm the updated 22 3.0 bones. not the original 3.0 bones, also you need to run alumn rear hubs with special 1.5 off set inserts. I know BMI makes them. have to email them
RandyB is offline   Reply With Quote
Old 11-10-2016, 03:18 PM   #4293
Logi Maker's Avatar
Trader Rating: 49 (100%+)
I refuse to run a front wing.... forever.
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 11-11-2016, 03:47 AM   #4294
eper's Avatar
Trader Rating: 14 (100%+)
Give it time you'll come over to the darkside
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 11-11-2016, 06:31 AM   #4295
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Sorry for the dumb question guys but I am new to the whole MIP puck thing as it came with my buggy so I don't know much about them.
Anyway, I think I have this based on how it looks:
https://www.amainhobbies.com/mip-puc...p16080/p520428
in my haste I thought all I needed was this:
https://www.amainhobbies.com/mip-b6-...p16041/p532350
but when I got it all together (of course then) looking at reasonable levels of droop the part that goes into the outdrives appear to be coming out.
Anyway, what would be the right part to be able to use the gear diff setup from MIP, I am thinking bones but not sure what to order? Is it this:
https://www.amainhobbies.com/mip-ass...p16040/p531932
and considering mine has what appears to be that two piece assembly of the bone (the gun metal to black part the "yoke"? ), does this replace that completely? (sorry just don't want to order and find out I am wrong).
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 11-11-2016, 09:58 AM   #4296
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I am not using these on mine, but I have them just in case. The bone is a little short on the b6, but completely doable. but these spacers will move the axles inward 1mm and make less prone to issues. Are you using the middle row of holes on the C and D block?
http://www3.towerhobbies.com/cgi-bin...1&I=LXFRHG&P=K
Also, MIP just came out with new titanium bones that are 1mm longer as well.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-11-2016, 10:43 AM   #4297
CCristo's Avatar
Trader Rating: 55 (100%+)
I think you mean Exotek
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 11-11-2016, 11:47 AM   #4298
JAE
Trader Rating: 26 (100%+)
Anyone use the factory associated +1 steering blocks for increased ackerman? Is this the same geometry as Schelle and any marked difference in cornering? Thx
JAE is offline   Reply With Quote
Old 11-11-2016, 12:02 PM   #4299
Tech Legend
Cain's Avatar
I am using the stock B6 pisitons which from memory are still middle row oriented holes (no vertical orientation),
For the pic of the exoteks, seems still short on engagement but could be wrong:
Old 11-11-2016, 12:23 PM   #4300
Trader Rating: 16 (100%+)
I'm testing them tomorrow I'll report back
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Scott R is offline   Reply With Quote
Old 11-11-2016, 12:30 PM   #4301
Default Lifting Front Inner Wheel
Running the B6 indoors on turf. Using stock set-up. Handles well. Only on sweepers the front inner wheels lifts. Wondering if I should stiffen the rear? Thanks.
Lextek is offline   Reply With Quote
Old 11-11-2016, 12:39 PM   #4302
Tech Legend
Cain's Avatar
exotek got back to me, they did there testing of the bones prior to the gear diff option, so I wouldn't be surprised those don't work.
Old 11-11-2016, 02:03 PM   #4303
racing on carpet I assume? just get the AE +1mm spacers
Old 11-11-2016, 02:09 PM   #4304
fast-ho-cars's Avatar
http://www.exotekracing.com/b6-hd-pu...-bone-systems/
no spacers needed....i hope. i run a ball diff
fast-ho-cars is offline   Reply With Quote
Old 11-11-2016, 04:58 PM   #4305
Originally Posted by Fearo View Post
Would someone who owns a B6 (laydown) be able to do me a huge favor?
Could you measure me the exact distance (in mm) between the motor protector brace and the back of the (preferably shorty) servo?
Please state if this is with a shorty or regular servo. Many thanks in advance.
I measured mine with a Savox 1251 Shorty Servo, at 123-125mm. Sorry best I could do. its tough to get my calipers in there
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
05PSD, asadrian, Bull_Dog
