    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree311Likes
Old 11-08-2016, 02:17 AM   #4246
RCWERKZ's Avatar
How is the wear on the arms. Anyone have to change them out already?
Any issues? Other and front shock towers?
RCWERKZ is offline   Reply With Quote
Old 11-08-2016, 03:33 AM   #4247
Default Shock pistons
What is everyone using for shock pistons the stock ones or machined ones? And what about the VRP pistons anyone tried them ?
Renracer is offline   Reply With Quote
Old 11-08-2016, 05:18 AM   #4248
RandyB's Avatar
Most are using a combination of 2x1.6, 2x1.7, and 3x1.4. I have been using the FT machined variants and have the vrp's to try. everyone that I know that trys the VRP's loves them. 2x1.6 front and 2x1.7 rear.
RandyB is offline   Reply With Quote
Old 11-08-2016, 05:23 AM   #4249
Quick question, I'm installing the aluminum "D" block (91688).
If I put the 0 arm mount insert into 91688, does that equal the stock setup which used the kit part 91692?
I ask this question so I know where baseline is...
Thanks in advance.
Consistent is used in the RC industry as much as Rowdy is used in the mountain bike industry. Truthfully, the only consistent thing is change.
BigChris in PA is offline   Reply With Quote
Old 11-08-2016, 05:27 AM   #4250
jmcelroy42's Avatar
Thanks in advance.
Yes.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 11-08-2016, 05:39 AM   #4251
I use stock ones, work just fine
eortizr is offline   Reply With Quote
Old 11-08-2016, 05:41 AM   #4252
Originally Posted by kiwiazbro View Post
Anyone had issues trying to get any of the supplied servo horns in the kit to fit on a Savox servo? None seem to fit.
do yourself a favor and just get the aluminum one, works great
Old 11-08-2016, 06:27 AM   #4253
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
question on the variety of chassis protectors, I forget the name of it but the one I have seemed to come in two pieces so you could remove the rear part that covers the screws for the tranny. maybe even the front too (haven't looked that far yet).
Anyway, in general what are you guys doing to keep the "stick" of the protectors when you go to service the vehicle?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 11-08-2016, 06:34 AM   #4254
JsK
JsK's Avatar
We use this, nobody at our track pays 15bucks for a chassis protector anymore.
http://m.homedepot.com/p/2-in-x-50-f...3550/100179778
freezeframe007 likes this.
JsK is offline   Reply With Quote
Old 11-08-2016, 07:34 AM   #4255
TAMAK's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Eli View Post
Are you saying they were running both the spacers to lower the bulkhead and the gull wing setup?
Putting 1mm worth of spacers to lower the bulkhead gives you a lower roll center in the front of the car, it calmed it down really.
LOWER front roll center
* More on-throttle steering
* Car is less responsive
* Better on smooth, high grip tracks with long fast corners
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-08-2016, 07:41 AM   #4256
I have been cutting holes out of the protector to access what ever screws I need to get to. I'M running on astroturf only so I don't have a problem with the screw heads filling up with dirt with the screws showing
roysays is offline   Reply With Quote
Old 11-08-2016, 07:42 AM   #4257
Yes.
Thank you
Old 11-08-2016, 07:51 AM   #4258
Tech Legend
Cain's Avatar
thanks I'll give that a look
Old 11-08-2016, 07:52 AM   #4259
Tyrant RC's Avatar
B6 looks awesome
Fernando Vega
MT-4
B5M
Tyrant RC is offline   Reply With Quote
Old 11-08-2016, 07:59 AM   #4260
Eli
Eli's Avatar
That's what I was thinking, built mine up last night with that combination, gull wing and the 1mm spacers on top of the bulkhead. What im curios to know is where they're running their axle heights/bump steer and what if any spacers on the rack.
Eli Westrup - SDRC Raceway
Eli is offline   Reply With Quote
Currently Active Users Viewing This Thread: 12 (3 members and 9 guests)
jchammbone, Jordan127, rp180sx
