Team Associated B6 & B6D thread
#4007
4 gear stand up
Just built the 4 gear stand up. Does it matter what side the ball diff hex bolt head faces?
In the manual for the standard 3 gear it mentions to have the ball diff hex bolt head same side as spur gear. In the sc5m manual which has the 4 gear it mentions the opposite. Ie ball hex bolt head opposite side to spur gear.
Mark
Mark
#4009
I just bought this kit (B6D), is any pinion included with the kit or do I have to buy it???
#4011
Mark
Mark
I ALWAYS put the head on the side that has the slipper nut so I remember which side it's on...
No pinion or wheels /tires..
#4012
Mark
Mark
#4013
Thanks for the responses everyone. I guess our area is a little different and go through a bit more of those items. I have a feeling its more track challenge related than anything.
#4015
My current track is dirt hard packed high bite, medium traction, should I just build the car with the lay-down transmission from the get go? is it that better?
#4017
If you don't have the lay down yet.. build it as is... order the lay down and switch it out and see which one works better for you. Worse case you're out $25 but you'll know for sure that you chose the best setup for how you drive.
#4019
thanks
#4020
Honestly it depends on traction level. low-med...standup & medium to high...lay-down. To judge on purely how both transmissions handle...lay-down all day long. You can carry more corner speed, jumps flatter and just transitions side to side much better. I run the lay-down with the 24g weight.
