Team Associated B6 & B6D thread
#3931
You are correct. After I installed the turnbuckles, it didn't travel as far and comes no where near touching the top plate any more.
#3932
#3933
Great looking build!
#3935
Only thing bad about the aluminum hubs in the rear is no height adjustment. I will continue to use the plastic till a b6 specific rear hub comes out with the height adjustment.
#3938
#3940
Looking to join my local rc group after moving to a new state and thinking of going with the b6 for their indoor winter carpet racing series. what are some must have upgrades, or upgrades to make the b6 solid for carpet racing, or just more bulletproof in general. cost isnt an issue. thanks
#3942
#3943
Servo horn
Which aluminum servo horn is everyone using? I run a Savox 1258. I used the same servo horn I used in my B 5M and it hits the top plate.
#3944
I went with only 1mm Ackerman washers on the steering rack and the middle hole on the rear inner camber link.
#3945
I use this servo horn for Futaba/Savox 25T spline:
https://www.amainhobbies.com/team-as...sc1366/p507395
There is other good ones if you search B6 Servo Horn on AMain.
