    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 05-06-2016, 12:12 PM   #376
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by Jmuck69 View Post
Nope, RM is dead.
Flamming to begin in 3...2....1....
RM is still great. My buddy's friend's cousin, who knows a guy that is fast said so.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 05-06-2016, 12:13 PM   #377
Jmuck69's Avatar
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-06-2016, 12:13 PM   #378
Has anyone thought about a mid motor design that can be rotated or reconfigured to be rear motor version?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 05-06-2016, 12:14 PM   #379
the tlr 2.0 can do that
Old 05-06-2016, 12:57 PM   #380
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
and kyosho rb6, and durango dex210, and sworkz buggy, and....
RC*PHREAK is offline   Reply With Quote
Old 05-06-2016, 01:07 PM   #381
people still own durango, lol. The kyosho in RM config is pretty good. That was my favorite rm car.
Old 05-06-2016, 01:24 PM   #382
RC*PHREAK's Avatar
never tried any of the more current RM's. went right from 4.2 to B5M.
Old 05-06-2016, 01:28 PM   #383
I had a 22 rm before the B5, them b5m. I was racing outdoors and it was ok. I could never make it great. The b5 rm was much better imo. Then I moved and started racing indoor high bite and have run the b5m since. I really liked the b5m. I am hoping the B6D is even better.
Old 05-06-2016, 01:34 PM   #384
RC*PHREAK's Avatar
i'm thinking the hot ticket at my track will be the laydown tranny with the flat front arms. so i'll probably end up buying the B6D and the laydown parts (i'll be curious to see the weight of this setup). i'll probably wait and see what the hot ticket at my track is. we already have a few fast guys that run a laydown.
Old 05-06-2016, 01:44 PM   #385
Kody said the running weight "should" be lighter than the b5m lite. He didnt give any specific numbers that I saw.
Old 05-06-2016, 01:51 PM   #386
Gigasipke's Avatar
Wow, my B5M lite with standard electronics and 3 gear was 1522 grams. B6D might be right at the 1499 gram weight limit then.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 05-06-2016, 01:56 PM   #387
Jmuck69's Avatar
Even more weight savings if you fill your shocks half full.
B6D | B64D
Old 05-06-2016, 02:00 PM   #388
I fill my tires with hydrogen gas to make them lighter.
Old 05-06-2016, 02:31 PM   #389
I pre-ordered the B6D and plan to do the laydown swap too. I run a laydown gearbox now and love it, so the new car should only be better, amirite?
boucher is offline   Reply With Quote
Old 05-06-2016, 04:58 PM   #390
Cridd's Avatar
Trader Rating: 16 (100%+)
Pre-Ordered the B6 and B6D so I can use the trannys as needed and have some extra parts. Car looks refined, should see a losi 4.0 by the time we can drive the B6's .
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Sal Amato
